16" Archtop
16" Archtop
Post by 56nortondomy » Wed Aug 18, 2021 5:14 pm
Just finished another archtop which i'm really happy with. All the timber is master grade quality.
Spruce top
Blackwood back sides and neck and headstock veneers.
Gidgee finger rest, f/b and tail piece.
Evo gold frets.
Marri bindings.
Kent Armstrong pickup.
K&K internal twin spot pickup.
Schaller locking tuners.
Miritone 3220 lacquer finish.
seeaxe
Re: 16" Archtop
Post by seeaxe » Wed Aug 18, 2021 7:10 pm
Lovely. Love the wood combinations and the binding looks great. Does the soundport make much difference with an archtop??
Re: 16" Archtop
Post by ozziebluesman » Wed Aug 18, 2021 7:34 pm
That's a fine looking Archtop. The Blackwood is very special and all your appointments make a stylish guitar. I like the idea of the Kent Armstrong and K&K pickup combination. I would also be interested in if the sound port makes a difference to the player experience sound wise.
Beautiful guitar Wayne.
Re: 16" Archtop
Post by 56nortondomy » Wed Aug 18, 2021 9:55 pm
Thanks Richard and Alan. I think the sound port does give the player that little bit extra, it does make a difference even on an archtop. I'm really pleased with those bindings, I've never used Marri before but I'm definitely using it again, I bought another 2 dozen pieces and have used them on the classical I'm building, they look great with the HRW I'm using.
WJ Guitars
Re: 16" Archtop
Post by WJ Guitars » Thu Aug 19, 2021 7:03 pm
Another great guitar build. With the pickup and K & K set up can they both switch on together.
Re: 16" Archtop
Post by 56nortondomy » Thu Aug 19, 2021 10:29 pm
Thanks Wayne. No there's separate jacks for them. The toggle switch is for the coil tap on the Armstrong pickup.
Re: 16" Archtop
Post by lamanoditrento » Fri Aug 20, 2021 10:24 am
Lovely looking archtop Wayne, well done.
Re: 16" Archtop
Post by 56nortondomy » Fri Aug 20, 2021 7:15 pm
Thanks Trent.
Re: 16" Archtop
Post by Mark McLean » Sat Aug 28, 2021 9:02 am
I love it Wayne. I have a mate who wants an archtop so I am planning to try my first one some time soon. Where do you source soundboard timber? I would be thinking of spruce or Huon pine. And what about those nice blackwood billets?
Re: 16" Archtop
Post by 56nortondomy » Sat Aug 28, 2021 4:43 pm
Thanks Mark. The spruce top came from ASW, the back and sides came from Tim ( Australian tonewoods) also the neck and bindings. I'm not sure where you'd get a huon top, I have one here that came from Pete before he dropped off the grid. You could ask Tim he might be able to help.
Re: 16" Archtop
Post by Mark McLean » Sun Aug 29, 2021 1:54 pm
Thanks Wayne. I will try those options . It is going to be a while before I wet started on that project but at least I am starting to plan and think about it, and to read Benedetto’s book.
mm
Re: 16" Archtop
Post by 56nortondomy » Mon Aug 30, 2021 4:36 pm
No problem Mark I'm happy to help.
Deano2
Re: 16" Archtop
Post by Deano2 » Tue May 28, 2024 10:56 pm
Very nice Wayne!
Curious to know if you follow the same recurve dimensions as stated in benedettos book for a 16" (assuming you're familiar with the book)
What thickness did you take your sides to for bending?
Cheers!
Re: 16" Archtop
Post by 56nortondomy » Wed May 29, 2024 4:44 pm
With the re curve I do it more by eye and touch than trying to get it exactly like the plans. I do try and get the right thickness though.
I always thin my sides to around 2mm to 2.2mm, at the cutaway section I thin to about 1.7mm to 1.8mm, depending on what timber I use.
Deano2
Re: 16" Archtop
Post by Deano2 » Sun Jun 09, 2024 8:11 pm
Thanks for sharing Wayne! Beautiful instrument.
Users browsing this forum: Google and 25 guests
