Tasmanian Tiger Myrtle and King Billy Pine Dreadnought
- martintaylor
Thought I'd post some pics of my latest build.
Back and sides - Tasmanian Tiger Myrtle
Soundboard - King Billy Pine
Bindings - WA Jarrah
Neck - QLD Maple
Fretboard and bridge - QLD Mulga
Soundboard bracing - Bunya Pine
Pickup - LR Baggs StagePro Anthem
OK, I admit it, I love Australian tone woods.
It's only a couple of days old and it is already sounding great. The LR Baggs pickup is so good. Captures the natural sound of the guitar and has all the control I need in a live situation.
Neck - QLD Maple
Martin Taylor
- steve roberts
Re: Tasmanian Tiger Myrtle and King Billy Pine Dreadnought
Hi Martin
Another really great looking guitar the tiger myrtle looks fantastic.
I recived my first LR Baggs stage pro anthem today . Do you have a template for the cut out or just measure and cut the hole ?
Regards Steve
Regards Steve
- martintaylor
Hi Steve, I used the paper template they supplied and I used double sided tape to stick it in position. First, I drilled the screw holes (in stages) then I drilled the corners of the cutout, then I used my Dremel with a cutting wheel to cut it out. One of my side supports was in that section so I had to use a small router bit in the Dremel to cut away a little of the ends so the system sat up in the hole correctly. It went in really well. Oh, and the hole for the jack/strap larger than other pickups I have installed. I covered the area in low tack masking tape and then drilled the hole in stages. It sounded great through our sound system at church.
Martin Taylor
- steve roberts
Thanks Martin
They did not supply the template so i will have to make one.
Regards Steve
Regards Steve
- martintaylor
I've always received the paper template. bummer.
Martin Taylor
- steve roberts
Many thanks Martin
I have emailed lr baggs for copy thanks to some imformation from Dale
Thank you both very much.
Regards Steve
Regards Steve
Looks great Martin and great to have the feedback re the LR Baggs StagePro Anthem.
Might have to order one myself.
Mike
Hi Martin,
Did you make any changes from "normal" bracing for the King Billy top? I have a King Billy top in my tiny stash and often wondered if the braces needed to be more substantial than for a spruce top?
Thanks,
GregL.
Thanks,
GregL.
- martintaylor
HI Greg,
I used the standard X bracing that I do (not confident to dive into the Gore method yet). The King Billy I had was nice a stiff so all went well.
Martin Taylor
I'm just wondering where you keep turning up all that beautiful TM? Might have to have you followed for a bit to find out....
Users browsing this forum: No registered users and 98 guests
