Page 1 of 1
Maurice 12 string
Posted: Fri Nov 21, 2014 3:10 pm
by Peter Young
Hello all ...
Maurice the machine had a 12 string commission.
Back / sides IRW
Top Sitka
Bindings Tas BW
Maurice made a 12 string.jpg (94.81 KiB) Viewed 26482 times
Plays great ... sounds fantastic
Peter
Re: Maurice 12 string
Posted: Fri Nov 21, 2014 7:12 pm
by Allen
What a bloody clever way of doing a 12 string peg head.
Posted: Fri Nov 21, 2014 10:36 pm
by charangohabsburg
Allen wrote:What a bloody clever way of doing a 12 string peg head.
Exactly my thoughts!
Posted: Fri Nov 21, 2014 11:01 pm
by Peter Young
Yes ... The customer had seen something like it on a Rickenbacker electric.
He liked the look of it rather that the traditional long headstock.
All credit to Maurice to nut it all out and execute the build.
Pete
Posted: Fri Nov 21, 2014 11:52 pm
by Kim
Superb work as always Mauri...thanks for posting Pete, very inspirational. :cl :cl :cl
Posted: Sat Nov 22, 2014 4:37 pm
by Kamusur
Good things happening in the west again, and that headstock is insane Mauri.
Posted: Sat Nov 22, 2014 7:47 pm
by kiwigeo
I need time to digest that headstock. Its a bit like walking around a corner and running into Jesus :shock:
Posted: Sun Nov 23, 2014 12:26 am
by maurie
It was done at the request of the owner, wanting 12 tuners on a standard size headstock similar to Rickenbacker 12 strings.
I was hesitant at first but told him I would give it a go with an all care but no responsibility attitude. I had concerns with strength of the headstock, function difficulty of the tuners and clear string paths. I drew it up full size and this indicated that tuners with a small footprint and long shafts would be required to leave enough meat after drilling for the tuners. The longest and smallest tuners that I could find readily available were Schaller M6 Mini. As it turns out I would have been happier with longer shaft tuners to increase the headstock thickness and the distance from the edge to the slot.
Tuning up was a lot easier than I anticipated. On the bass side, normal tuners are the main strings and slots are the octaves. On the treble side it is the opposite.
The 6 pin bridge works a treat also, even if a bit more challenging at first string up. Thanks to Craig and Martin for putting me onto this.
Cheers Maurice
Posted: Tue Nov 25, 2014 5:47 am
by Mark McLean
Hi Mauri
I'm impressed also by that feat of engineering and 3D design. Would you do it again, or recommend it to another customer?
Posted: Tue Nov 25, 2014 2:54 pm
by maurie
Hi Mark
Yes I would do it again and recommend it, providing I could obtain long shaft tuners with a small foot print.
Schaller M6 Minis are only 13mm wide which is great, but the threaded retaining screw length is the restriction.
Open tuners with a press fit bushes would be the way to go but the smallest body width I could find was 17mm which means the headstock thickness must be a min of 18mm. This means the shaft length is then too short.
I have heard that some tuner manufacturers do make longer shafts so I will check this out for future builds.
Cheers Maurice
Posted: Wed Nov 26, 2014 8:45 pm
by Kim
Not your regular wingnut style, but perhaps Steinberger's gearless 40:1 straight through tuners would do the trick for you Mauri...
http://www.stewmac.com/Hardware_and_Par ... ml#details
And then there's Gotoh's Stealth..these maybe interesting to you because they can be 'imbedded' into the headstock..an overlay held in place by a couple of small re magnets to cover the bodies of the tuners...and you would never know..that'll have'm scratch'in their heads 8)
http://www.g-gotoh.com/international/?page_id=2232
Posted: Thu Nov 27, 2014 11:51 pm
by maurie
I initially thought about stealth tuners based on their small body size, but felt they may not handle the tension of 12 to 53 strings.
However I have just checked them out and find they will handle 20kg of tension. Amazing.
This would make them ideal, apart from their cost.
Cheers Maurice
Posted: Tue Dec 02, 2014 8:53 am
by johnparchem
Wow!, What a gorgeous instrument.
