Page 1 of 1
Gidgee Classical
Posted: Wed Sep 02, 2015 12:01 am
by Trevor Gore
I did a search through the gallery and couldn't find anything with gidgee back and sides, so thought you good people might be interested in this one. Lutz top, figured gidgee back, sides and head plate, straight grained gidgee fretboard, "mad" gidgee bindings, NGR neck, "mad" gidgee segmented rosette with amboyna trim, with the amboyna also appearing in the head plate. Aus. Blackwood bridge, Gotoh premium tuners with real MOP buttons. All the gidgee was courtesy of Pete (Curly Timbers) and Jeremy at
http://www.australianguitartonewood.com. Thank you, gentlemen!
- DSCF6558Cs.jpg (119.14 KiB) Viewed 26920 times
- DSCF6677s.jpg (60.24 KiB) Viewed 26920 times
- DSCF6680Cs.jpg (77.39 KiB) Viewed 26920 times
- DSCF6689Cs.jpg (121.59 KiB) Viewed 26920 times
- DSCF6614s.jpg (79.37 KiB) Viewed 26920 times
- DSCF6582Cs.jpg (101.47 KiB) Viewed 26920 times
Re: Gidgee Classical
Posted: Wed Sep 02, 2015 1:23 am
by martintaylor
Wow, Trevor, it looks amazing. Am I right in assuming the mass of the back and sides negates the need for any extra side mass? And, what was the gidgee like to bend?
Posted: Wed Sep 02, 2015 10:49 am
by kiwigeo
What's the finish Trevor...hard shellac?
Posted: Wed Sep 02, 2015 10:51 am
by Trevor Gore
Thanks, Martin. The extra mass helps with projection, but the side masses are also about tuning the main top resonance. I managed to land the resonances close enough to where I wanted them without trimming with additional side mass, so as it happens, this guitar hasn't got any side masses in. It weighs about the same as an EIR guitar with sides masses.
Straight grained gidgee should bend fine - it just needs to be very hot, then it plasticizes well. The highly figured stuff is very difficult to get smooth bends in. The bindings have grain that runs straight through the thickness, so were a real challenge. Gidgee is very brittle when cold. As I was cutting the bindings some of them broke as they flopped off the saw!
Posted: Wed Sep 02, 2015 10:52 am
by Trevor Gore
The finish is hard shellac on the top, the rest nitro.
Posted: Wed Sep 02, 2015 6:26 pm
by Alan
Posted: Fri Sep 04, 2015 7:45 pm
by curly
Gorgeous work Trevor ,
Man what an honour to see a work of that calibre made from my timber . And we'll done taming that gidg , that was some cranky timber !
Pete
Posted: Sat Sep 05, 2015 8:21 pm
by soulman
Beautiful work Trevor. Nice piece of Gidgee.
Posted: Fri Sep 18, 2015 1:20 pm
by Dennis Leahy
Wow, that is beautiful, Trevor. What a set of wood, and you did it proud.
Posted: Fri Sep 18, 2015 2:19 pm
by demonx
What a stunner. I'm sure anyone would be proud to own that one.
Posted: Fri Sep 18, 2015 3:34 pm
by H3ytm@n
Posted: Wed Oct 28, 2015 11:44 pm
by kpcart
nice work.
great that you got the binding to match.
what sort of bracing is it? fanned? and did you use traditional 3 braces on back?
how did you decide the bridge shape? , looks very light weight, do you have a bridge plate?
red cedar or Spanish cedar neck?
it is interesting you got the weight down, is it under 1.5kg?
what bracing wood inside?
can you do a sound sample?
I ask all this because I like it from the photos
Posted: Fri Oct 30, 2015 10:01 am
by kiwigeo
Trevor will no doubt answer all your questions.
You had alot of criticisms for Martin Taylor's recent classical build....be warned that Trevor's builds are about as "non traditional" as you can get
kpcart wrote:nice work.
Posted: Sun Nov 01, 2015 11:00 pm
by Trevor Gore
kpcart wrote:what sort of bracing is it? fanned?
Falcate for classical.
kpcart wrote:...did you use traditional 3 braces on back?
No. I haven't given a name to the back bracing I use, but I use the same system for SS guitars as well. It's in the book; three transverse braces and a "star burst" in the lower bout.
kpcart wrote:...how did you decide the bridge shape?...
Structural efficiency.
kpcart wrote:...looks very light weight, do you have a bridge plate?
Yes, it's light. And no bridge plate.
kpcart wrote:it is interesting you got the weight down, is it under 1.5kg?
No.
kpcart wrote:...what bracing wood inside?
Spruce.
kpcart wrote:...can you do a sound sample?
It was a commission. Gone already.
And thanks to everyone for all the kind comments.
Posted: Thu Nov 05, 2015 8:08 pm
by blackalex1952
Call it Star Burst bracing! Or maybe big bang bracing?
