Target Thickness for a 12 string
bdunne
Post by bdunne » Tue Jul 30, 2013 6:56 am
Hi,
Building a 12 string and it occurred to me that the result for calculating the target thickness of the soundboard for a 12 string may need to be modified slightly. Perhaps the vibrational stiffness figure? If anyone has some experience applying the equations for a 12 string I would appreciate your comments.
Brian
Re: Target Thickness for a 12 string
Post by Trevor Gore » Fri Aug 02, 2013 9:31 pm
I was hoping someone else would chime in before me, but obviously not....
I usually keep the same vibrational stiffness figure and beef up the bracing using a sparse lattice.
bdunne
Post by bdunne » Sat Aug 03, 2013 9:41 am
Thanks Trev,
I take it that you regard Lattice bracing as being more stable than more traditional X bracing then?
Brian
Post by DarwinStrings » Sat Aug 03, 2013 10:43 am
Hi Brian, page 4-53 black book, the last paragraph on the page in the Section Summary might answer that question for you.
Post by Trevor Gore » Sat Aug 03, 2013 11:08 am
bdunne wrote:I take it that you regard Lattice bracing as being more stable than more traditional X bracing then?
I think it's more efficient, in that you can get the stiffness you want using less material than you would with X bracing, without the stiffness singularities. Take a look at the pictures on page 1-23 (Design).
