Difficulties determining Cross Grain mode (fC)
Edzard
Post by Edzard » Sat Oct 11, 2014 12:58 am
Hello All,
I several tops where I have troubles finding the Cross Grain mode. When I tap/recored I find (mostly) two frequencies which stand out.
For example I have this top:
And the following recordings:
Twinsting vibrationmode (fLC) at 59 Hz.
Long grain vibrationmode (fL) at 84 Hz.
Then the Cross grain vibrationmode (fC):
Or moving allong the node line:
and
With F Cross at 185 Hz I get a Elong/Ecross of 0,78.
With F Cross at 87 Hz I get a Elong/Ecross of 63.4 (which seems very high).
Can I therfore exclude the 87 Hz mode for the Cross grain?
Thanks again for your input.
Best regards,
Edzard
Re: Difficulties determining Cross Grain mode (fC)
Post by Trevor Gore » Sat Oct 11, 2014 5:02 pm
Checking P 4-63, Table 4.5-3, I'd say the 185Hz figure is likely the correct one, given the thickness you have.
You might try using G-tune, which I find easier for this sort of thing. Downloadable from here:
http://www.jhc-software.com/downloads.shtml
Double click on the frequency meter to get a larger display...
Edzard
Post by Edzard » Sun Oct 12, 2014 6:29 am
Thanks for the reply and tip!
I will give it a try.
Best regards,
Edzard
