Paulownia fas bridge material?
JurgenV
Post by JurgenV » Sun Oct 20, 2019 4:35 am
I wasn´t sure if I should start a new thread for this or if I should post in the old thread with the two OOO I´m building.
I had some problems to get the weight of my bridge under 23gr with my walnut blank so I ordered Padouk at my wood supplier. I asked for a blank with low density and explained to him why. When he send the wood he included a piece of Paulownia wood for free and told me to try it as it´s very light and strong.
Does anyone have experience with this wood and perhaps used it already for making a bridge?
Juergen
JurgenV
Re: Paulownia fas bridge material?
Post by JurgenV » Sun Oct 20, 2019 7:00 am
is there any way of correcting the text or title of a posted thread?
That´s already the second time I made a mistake in the title and couldn´t find a way to correct it
Post by Trevor Gore » Sun Oct 20, 2019 10:12 am
The Paulownia I've had is only one step removed from balsa and quite soft. I doubt it would hold up using the designs in the books. With some very cunning design work it might work, but I suspect some pretty complicated manufacturing would be required.
JurgenV
Post by JurgenV » Mon Oct 21, 2019 4:39 am
Thank you for the fast reply Trevor.
Means I can save my time and leave this wood for some other project (whatever that will be). Let´s see how far down I will get the weight of the padouk bridge.
Post by kiwigeo » Mon Oct 21, 2019 9:01 am
I'd be happy with 23 grams.
JurgenV
Post by JurgenV » Wed Oct 23, 2019 8:13 am
With the Padouk Ißm down to 18.6gr. Should be fine
