Feathered braces v tucked braces
Bruce McC
Post by Bruce McC » Tue Jul 08, 2025 2:38 pm
On the J 45 drawing #1 only the top end of the X braces are housed into the linings.
The bottom ends of the X braces are feathered and not set into the linings.
Is this normal on all X braced guitars? Does this make for a more responsive top?
Bruce Mc.
Re: Feathered braces v tucked braces
Post by Trevor Gore » Wed Jul 09, 2025 9:20 am
Most guitars have the bottom ends of the X braces set into the linings, which is fine if you want a truly "robust" guitar which will effectively double as a baseball bat.
Does this [feathering] make for a more responsive top?
Yes, substantially. Does it make the guitar more fragile? Not dangerously so. My guitar, from which the drawings were made, is over 25 years old, has mostly been strung with 13s, and survived a drop from waist height onto a wooden floor, landing on the lower bout treble side binding and survived virtually damage free.
Bruce McC
Post by Bruce McC » Wed Jul 09, 2025 4:36 pm
Thank you Trevor. Speaking of baseball bats must try hickory for back and sides on the next steel string.
Bruce Mc.
Post by kiwigeo » Wed Jul 09, 2025 8:05 pm
"survived a drop from waist height onto a wooden floor, landing on the lower bout treble side binding and survived virtually damage free."
But has it survived the ultimate test of resilience.....a full on bar room fight?
