Howdy guys
Getting ready to brace up a back. In Fig. 11-3 (Build), the radial braces are 115mm long, 50mm from the center of the third ladder brace, and according to the text on pg 11-7, should end about 10-15mm from the inside edge of the linings.
So, should I make the brace however long it needs to be so that it starts 50mm from the center of the transverse and ends 10-15mm from the inside edge of the liners, or should I made it 115mm long regardless, position it so that it ends 10-15mm from the inside edge of the liners, and the distance from the inside end of the brace and the centerline ends up being whatever it is?
Radial back braces for live backs
Re: Radial back braces for live backs
I vary the brace length commensurate with the width of the box. I start the brace ~50mm from the center and end it ~20mm from the inside of the linings, measured along the line of the brace. Then the brace is whatever length it turns out to be. It's not a critical dimension.
Thanks as always, Trevor!
