Wood for Falcate Braces in UK
Mitch Lees
Post by Mitch Lees » Fri Mar 22, 2019 7:14 pm
This a question for UK-based members. I am building my first falcate braced steel string as per the plans from the 'books'. Which wood have you used for the braces, and where have you sourced it please? My preliminary experiments with the Sitka and European Spruce I have to hand have not gone well!
Grateful for any guidance.
Mitch
johnparchem
Re: Wood for Falcate Braces in UK
Post by johnparchem » Sat Mar 23, 2019 3:31 am
Not in Europe, but I use sitka and englemann spruce. I thickness to 1.7 mm strips and bend them to form on a hot pipe before laying them up. What issues have you had with spruce.
Dave M
Post by Dave M » Sat Mar 23, 2019 3:52 am
As with John I use spruce and could not bend thick strips so ended up with more, thinner laminations. Even then I wasn't particularly pleased and some snapped during bending but eventually got acceptable results.
Hot pipe bend then the primaries clamped to an inside caul for glueing and for the secondarys I have made inner and outer moulds to squeeze that tight bend.
Oh and while you are at it do several sets while you have all the gear out - you know you'll be making another one or two!
Post by kiwigeo » Sat Mar 23, 2019 11:58 am
My experience the same as Dave's.
Post by Trevor Gore » Sun Mar 24, 2019 12:51 pm
Some spruce will heat bend and some won't. And you can't tell until you try. That's just how it is. None of the spruce I had would bend when I first tried making falcates. But I'd heard that spruce was heat bendable and without too much trouble. When I replenished my supplies, the new stuff would bend. Ostensibly the same wood. The wood that won't bend makes good back braces and transverse braces!
Mitch Lees
Post by Mitch Lees » Mon Mar 25, 2019 2:03 am
Thank you for your responses. It seems the spruce I have been trying to use was of the 'will not bend without breaking' variety. Because of this very limited experience, I had assumed all spruce was like this. However, I have another batch of spruce brace wood which I will now try - hopefully it will be more cooperative!
Many Thanks
AKEric
Post by AKEric » Tue Mar 26, 2019 6:00 am
I have had 100% good luck with sitka. I use very precise male/female forms that clamp together and support the wood well. I use three, 1/16" thick plys. The forms were made using a 3/16" diameter, bearing guided straight router bit so they exactly match the width of the three finished plys.
I glue with TiteBond, and because the forms clamp so tightly there is no warping across the width; little if any spring-back.
For the primary braces, I bend and glue them dry with good luck.
The tightly curved secondary braces are a bit more finicky. I made a small steam chamber and steam the three strips for about 5 minutes. They bend in the form without any issue. Of course, they need to cure and dry out before gluing together.
I've done a lot of steam bending over the years, so I have the steam generator. You can easily use a kettle and a hose as well.
Falcate brace bending forms. Dowels slide in slot for precise alignment.
Secondary brace bending form.
Steam generator and steam chamber.
Post by kiwigeo » Tue Mar 26, 2019 8:37 pm
Nice looking jigs Erik. My brace bending jig is a bit more "agricultural" :) I use epoxy resin to glue up strips that are around 2.2mm thick. The strips are held against the form with a picture framing band clamp with additional clamping pressure supplied by spring clamps. Paste wax is applied to the form before glue up to stop the braces sticking to the jig.
Steve.Toscano
Post by Steve.Toscano » Tue Mar 26, 2019 10:45 pm
I use engelmann (and at times also use King Billy Pine).
3x 1.9mm laminates.
I've had pretty good success with finding engelmann that bends well, the trick is to dunk it in water that is straight off the boil - very hot, then straight onto the iron.
Below is my 'bondage' :lol: clamp for the primaries, same for the secondaries.
The jig is 30mm wide, i glue up my falcates at 25mm then slice down the middle to get to 2x matching halves.
The black rubber is bike tyre tube kindly donated by the guys in lycra who were having breakfast at the table next to me at the local cafe one sunday morning.
2019-03-26 22.36.19.jpg (215.33 KiB) Viewed 20596 times
AKEric
Post by AKEric » Wed Mar 27, 2019 4:29 am
Thanks Martin,
Yours is great too. The ingenuity of the luthier bunch never fails to amaze me. Anyone else want to share their process?
Mitch Lees
Post by Mitch Lees » Wed Mar 27, 2019 10:47 pm
Thanks all for going to the trouble.
This will be a great help - particularly the pics
Mitch
Woodsy23
Post by Woodsy23 » Mon Apr 01, 2019 1:31 pm
I must have been lucky with the spruce I got for my first falcate built as it bent easily. I clamped the end of each 1.7mm strip to a form of the appropriate shape, draped a damp cloth over it then ran a hot clothes iron over it to press it onto the form. Then I clamped the piece in place for a short time. There was some spring back but that was eliminated when the pieces were laminated together. That system worked and was really simple so I continued to use it.
gerryt
Post by gerryt » Tue Apr 02, 2019 1:17 am
Just bent my first falcate primaries and secondaries using Sitka from Timberline in the UK and it bent no problem. Thicknessed to 1.7mm and clamped to a form. The triple ply laminate was glued with West Systems epoxy.
jamtor
Post by jamtor » Thu Jan 14, 2021 11:24 am
fast forward to 12:10 . what kind of wood does this? :shock:
youtu.be/6YCBJQ3MF5Q
Post by kiwigeo » Thu Jan 14, 2021 1:52 pm
Looks like spruce. With a bit of coaxing you can get it to bend around a tight radius.
Not sure about the logic behind that "extra" brace going across the lower bout.....one benefit of Trevor's falcate bracing design is the sound board gets divided up into roughly equal inter-brace areas.
