Is two better than one?
- Beefwood
So I recently got the box closed and got a nice peaky spectrum. Pulled out the ol’ signal generator for come chladnis and I have two monopoles and two cross dipoles... and they correspond to peaks on the spectrum. Any idea what is happening there? Are resonances coupling somehow?
Re: Is two better than one?
Is one of the monopoles the back and one the top?
- Beefwood
Fraud not. I did a chladni on the back at 216
I do not see a spectrum spike at 216 Hz. I am wondering if your back is pitched a bit below the top and the back is showing at 206 Hz and the top at 230 Hz. You can stick some mass on the top and/or the back (like blue tac) and see how the peaks move in relation to each other.
- Beefwood
Ok I will try that to start. I suppose it’s possible. The back is built heavily. But the frequencies could be coupling when so close. Right?
Users browsing this forum: Google and 18 guests
