How to post a picture to the forum.
This is just a little tutorial for those having difficulty in posting images to the forum.
First off you click on the "Upload Picture" dialog box.
This will pop a window where you choose the picture file that you want to post. Remember that it must be in one of the formats listed. If it is not then this whole process is not going to work. The most common format for pictures is .jpg. or .gif Click on the "Choose File" dialog box.
This will open a window where you can choose the picture from your computer that you want to upload. You must then hit the "Send" button.
Depending on the size of the image and the speed of your connection, the image will be uploaded to the server and will display in this window for you. You must then hit the "Standard" button in order to insert the code that will display the image in the post, if all you are doing is posting one image. If you are posting more than one image, you can hit the "Insert image and upload another one".
- sebastiaan56
- Taffy Evans
- Taffy Evans
- John Maddison
Yo'all ... If ever you've taken images in HIGH resolution on a digi camera you'll notice they can be anything up to 2 megabytes or more EACH in file size. I've been using a nifty bit of FREE software for ages, called Irfanview, written by a Bosnian guy. Go to http://www.irfanview.com/ to download the software and stop by his help pages. It supports a gallery mode for all your stored pics, and is able to Image>Resize or Image>Sharpen or Image>Adjust Colour|Brightness|Contrast before you upload to the Forum. Have noticed the Forum's upload sequence says large pics will be resized (to fit standard webpage view I guess) but it MIGHT save a bit of time uploading large-file-size pics if you've resized them prior. Might be a blessing for those on diallup accounts, or wanting to send hi-res pics as attachments via email. A Google product called Picassa is also another good FREE image viewer.
Chiz
JohnFM
Chiz
JohnFM
John M
- Taffy Evans
You may find this hard to believe but over many years when I've had a challenge to over come and nobody to ask [often], the answer has always showed up in the next copy of the GAL publication. Last night after spending 2 plus hours trying to work out to upload a photo (after the well presented cant go wrong tutorial, above] , I gave up and decided it's text only from now on. So I'm not surprised to find the answer, next day, on the Forum. Freaky. I was not going to ask on the forum again cos the whole lutherie word will think I'm areal dummy, well you probabily worked that out already. But I have had Picasa for a number of years.
Thanks John..................now what did he say?
- John Maddison
It's OK Taff ... everything good (and FREE) comes to those who wait!
Important thing when using Irfanview is if you are manipulating an original large-size image and you want to keep the original in it's native size/format, it's best to do a File>SAVE AS, otherwise you lose the properties of the original if you choose File>Save. After you make all the changes to the original this step allows you to select an appropriate format (JPG or GIF for web or email, or TIFF for inserting the pic in a document) and folder location (I ALWAYS set up a different folder to save the new pics in, and always create an appropriate name .. e.g. 'ukulele-resized' or 'ukulele-sharpened').
You can also do BATCH processing of multiple images, can save huge amounts of time! ... but this is for advanced players. Muck around with a few pics one by one and see how you go - always happy to help if you get stuck (ping me a PM). I use Irfanview when teaching TAFE students who need to manipulate images, it's also the standard image viewer on all our work machines @ the College. You can also hook up a scanner to your PC and bring images straight in so that cropping, rotating, sharpening, resizing etc etc etc can then be performed. The Boznian dude's website has good support pages, and the Help/How To files within Irfanview are well written.
Keep pluggin' away, and always keep in mind the 3 R's of learning computing ... Repetition, Repetition, Repetition.
Chiz
Chiz
John M
I have use Irfanview for many years as well, it really is a VERY handy program.
For tech challenged folk like Taff however, if using Windows XP, it may be easier to download and use Microsoft Power Tools Image Resizer.
This is a nice easy to use little app that once installed will allow the user to simply "right click" on any image and in the selection menu will appear "resize picture". You simply select this with a left click and choose from the list of common image size resolutions displayed.
Once done, a copy of the image in the new resolution you have chosen, say 640 x 480 as in the example below, will be automatically created in the same folder as your original image. The new smaller image will even have the same file name, with the exception that the word "small" will be added and this is the one that you would upload.
The image shown below was downloaded as a huge 2048 x 1546 pixels or 1.44 meg and therefore much too big to upload to the forum or even save to a floppy. With a quick right click of the mouse, it was converted to a much more manageable 640 x 480 pixels or 68kb.
Anyhow, here is a link for the XP Power Tools Image Resize applet, hope this sorts your problem Taffy.
http://download.microsoft.com/download/ ... ySetup.exe
- Taffy Evans
- Taffy Evans
Way to go Taffy and a great looking instrument as well.
One thing to remember when you are posting multiple images is to hit enter after each one so it will appear on it's own line and they will align vertically rather than having the images all horizontally aligned making everyone looking at your post scroll across the screen to read any text which will follow the width of screen under the images.
What did you use to resize??
- Taffy Evans
- John Maddison
Re: How to post a picture to the forum.
Software changes from time to time. This is how I see the upload screen on the ANZLF by June 2012:
After clicking the Browse button select your picture file and hit the Open button:
I have translated the relevant parts that appear on my computer in German (by mid 2012 it was English)
Then click on the Add File button.
Depending on how busy and slow your computer is, it will sometimes take a few seconds until the "Upload is currently in progress" window will pop up. Wait until it automatically disappears (which also may take sometimes 10 or 20 seconds). Be patient.
Hit the Preview button to see how your post finally will look like.
Click the Submit button when you’re done with the whole editing of your post.
After that you will be allowed to edit your post during 5 seconds ....errmmm 5 minutes I mean, I believe....
I don't know what the allowed maximum size in pixels and bytes is. I normally resize my picture to 20 x 15 centimetres at 72 pixels per inch, which is 567 x 425 pixels (normally less than 50 Kb), which is big enough for most pictures, but you can upload bigger pictures. Rob (auscab) said here that the forum software will tell you the maximum sizes if you tried to exceed it.
Good luck!
Good luck!
