Cutting notches in braces
Dave M
Post by Dave M » Sat Jun 02, 2018 12:53 am
I realised that we already use a depth stop on our fret saw to cut specific depths and this could be used to do a series of cuts in a brace to be followed by a chisel. It worked well for me.
Re: Cutting notches in braces
Post by Trevor Gore » Thu Jun 14, 2018 8:20 pm
Nice one, Dave.
I've used a router recently. Do both braces together and space them apart a bit so that the router is stable. Set the depth by sitting the router base on the bridge plate + CF and drop the bit to the bench. Ends of cuts defined with saw cuts, as usual. Using the depth stop is a good idea. I've just been eyeballing it.
Post by kiwigeo » Fri Jun 15, 2018 10:17 am
Pretty much how Ive been doing mine of late....an ideal job for the Dremel and mini router base.
Nice one, Dave.
Steve.Toscano
Post by Steve.Toscano » Sun Jun 17, 2018 12:44 pm
Great idea!!
I have a small fine Japanese saw which turns out the teeth are cut exactly 2mm into the blade. So have been cutting the brace notches until the saws teeth disappear.
Post by Mark McLean » Tue Jul 03, 2018 10:36 pm
A couple of years ago I was lucky enough to get a Bridge City jointmaker second hand, for a pretty good price (a single wing - the "cheap" model). It is the Rolls Royce for doing precision cuts. Check out the video.
https://www.bridgecitytools.com/default ... maker.html
