New Luthier Tips du Jour Video - Vacuum Fixtures
Robbie O'Brien
ANZLF Approved Supplier
Post by Robbie O'Brien » Thu Nov 20, 2008 5:41 am
The latest Luthier Tips du Jour video is on the air. The topic is Vacuum Fixtures. I discuss the use of vacuum in the shop and show a couple of fixtures I use in my shop.
As always, comments and discussion are invited.
Enjoy!
youtu.be/
www.obrienguitars.com
Post by sebastiaan56 » Thu Nov 20, 2008 7:59 am
Thanks Robbie,
I really got sucked into that one....... :lmao :lmao :lmao :lmao :lmao :lmao sorry,
Nice guitar playing, was that you?
Robbie O'Brien
Post by Robbie O'Brien » Thu Nov 20, 2008 8:02 am
haha!! That was a good one!
The person playing the guitar is one of my guitar building students this semester. He is completing his first classical guitar with me.
Post by Mark McLean » Thu Nov 20, 2008 1:30 pm
Hi Robbie
Nice video, as always. The 360 degree rotating clamp system looks very useful. Where would I get one, and at what cost. I can see that they would be very worthwhile in a busy workshop, but I am a one-man weekend hobby builder.
Robbie O'Brien
Post by Robbie O'Brien » Fri Nov 21, 2008 1:05 am
Mark,
The hold down clamp and the bridge clamp are both LMI products. I worked for years without vacuum in my shop. When I added it I loved it and still find more and more ways to use the hold down fixture. Once you put vacuum in your shop you start thinking of jigs you can easily make yourself to do things. I didn't even go into this side of things in the video.
Sure you can work without vacuum but it sure is nice to have it.
hilo_kawika
Post by hilo_kawika » Fri Nov 21, 2008 2:15 am
Mark,
Here's an inexpensive version of the rotating vacuum clamp that I used many years ago.
As you can see, it's made mostly out of galvanized pipe and leftover fittings from my plumbing packrat box. The quick disconnect fitting at the bottom is from the auto parts store and leads to the vacuum source. A gas line valve opens and closes the system to the atmosphere. The wooden hinged thingie on the pipe goes into a vice wherein slight loosening of the vice allows for easy rotation of the device. The main pad comes from discarded mdf sink cutouts and the foam tape is closed cell weather stripping, again from the hardware store. I had many instrument-shaped plates that could be placed against the vacuum surface for different sized ukuleles. I think the vacuum system is ok, and LMI's version quite elegant but in the end I switched back to more traditional clamping systems. To each, his own...
aloha,
Dave Hurd
hilo_kawika
Post by hilo_kawika » Fri Nov 21, 2008 2:26 am
Robbie,
With respect to the LMI vacuum bridge clamping jig I would like to suggest that it's the amount of clamping pressure on the bridge rather than the total area of the jig that's the important number.
1 inch Hg ~0.5 psi (pounds per square inch)
19 inches Hg ~ 9.5 psi (your vacuum pressure in the video)
Let's say that your classical guitar bridge has an area of 6 square inches.
So, 6 sq in. X 9.5 psi = 57 lbs pressure on the bridge rather than the 228 lbs for the whole area calculated in the video. This amount of pressure should be sufficient assuming a perfect fit of the bridge under surface to the guitar top, which I also assume to be the case for your work. If there are any discrepancies in the fit however, the ~9.5 psi pressure may not be enough to clamp things properly.
aloha,
Dave Hurd
Robbie O'Brien
Post by Robbie O'Brien » Fri Nov 21, 2008 2:37 am
Dave,
You are correct. I failed to clarify that the 228 pounds of pressure is on the whole area of the clamp itself. The bridge clamping pressure is less.
