Drilling Headstock
- Hippety Hop
Drilling Headstock
If my inlay overlaps where the holes are going to be, what precaution should I take not to chip the shell?
Hip?
Hip?
Hippus Erectus
Hippus Erectus
- Taffy Evans
I have drilled shell. I start with a small sharp drill and build up, I also use that cutting paste on the drill that I put on my sawblade when cutting inlays. I'd also consider my Dremal and or a rat tail file. You could mark the pegholes on the peghead and finish the inlay just short of the hole outline, the washer or securing nut around the post will cover that. But I always put the hole in first and then plan the inlay.
- Hippety Hop
Glad you hadn't already glued your Mop Hip but had you done so this is a way around it and also a very handy little tool for your Mop kit.
One of the best ways to drill Mop I have found is to buy those diamond drill bits from Lapidary supply places. You can cut any size hole in one go without fear of breaking the Mop as they are abrasive rather than cutting edge tools. They are made for cutting stone and Mop is much softer.
They call them drill bits but they are more like hole saws as you not only cut a hole but you get left with a plug. I use them for cutting "dots" out of Mop rather than buying them when I have little offcuts anyway. One downside is that they don't have a center point so they need to be used in a drill press with the work piece held firmly. On the up though they are only a few bucks each.
My smallest one cuts around a 2mm dot. The one in the pic cuts a 6mm dot.
Don't mind at all Kim, I should have just put it in my reply anyway.
It was a company called Gemcuts Lapiday Supplies who are in Qld and NSW but you may find someone closer. Here is the URL.
http://www.gemcuts.com.au/index.htm
Users browsing this forum: Google and 116 guests
