How Do You Re-Affix a K&K Pickup?
John Maddison
Post by John Maddison » Thu Nov 25, 2010 4:00 pm
G'day
We've taken on a repair job of a 6-string acoustic where one of the three K&K pickup pads has come completely adrift from the bridge plate. Does anyone have good advice on what glue to use to re-affix same. We're thinking liquid CA would be too messy and we'd run the risk of permanently glueing a fingertip to the guitar in the process :oops:.
Is there a reasonably-fast-setting product (a Gel, maybe?) that you'd recommend for this kind of job. Cheers & thanks!
Maurie & John in Albany
John M
Re: How Do You Re-Affix a K&K Pickup?
Post by Kim » Thu Nov 25, 2010 4:11 pm
Yep a mid type CA is what is provided to install the buds by K&K. Check the K&K website and you should find a tute that will help you position the bud right where it needs to go...Positioning is 'everything' with these guys.
If you can find the tute, leme know and I will scan one up 4 u.
Here it is
http://www.kksound.com/jig.html
Here's a pdf of same (cool new forum software 8) )
jig.pdf
(884.16 KiB) Downloaded 795 times
John Maddison
Post by John Maddison » Thu Nov 25, 2010 4:37 pm
Genius as always, Kim!
Ta mate.
John M
Post by jeffhigh » Thu Nov 25, 2010 5:09 pm
just check the bridgeplate first with a mirror
Some people have used double sided tape to afix the discs so that they can be removed and you would not want to be gluing to this residue
Post by kiwigeo » Thu Nov 25, 2010 5:59 pm
Slip on a pair of disposable latex gloves while working with the CA if youre worried about gluing yourself to the bridge plate.
pat foster
Post by pat foster » Fri Nov 26, 2010 3:25 am
Then you'll only glue a glove to the bridgeplate! :D
I can see where gluing your finger would be a possibility, but if their instructions are followed carefully, that can be avoided. I'm the living testament to CA's tenacity, so if I can do it successfully, anyone can.
The double-sided tape might impact the sound.
Pat
Post by kiwigeo » Fri Nov 26, 2010 7:27 am
Correct, bit it's less painful and a bit easier getting a bit of glued on glove off the bridge plate than the end of your finger!
Post by Kim » Sat Nov 27, 2010 10:49 am
kiwigeo wrote:it's less painful and a bit easier getting a bit of glued on glove off the bridge plate than the end of your finger!
That would depend, if it s a finger style guitar then it may be a good thing to just leave it there. :?:
Post by charangohabsburg » Sat Nov 27, 2010 10:45 pm
"Fingerstyle" guitar! Image
Kim wrote: [...]
Here it is
Cool description, specially step 16:
This photo shows the jig inside the guitar (yes - we cut a hole in the bottom of the guitar).
:lol: :lol: :dru :mrgreen:
Rod True
Siberian Tiger
Post by Rod True » Sun Nov 28, 2010 12:08 pm
Wax paper is your friend when using CA. CA has a very hard time sticking to it, but double sided tape will stick to the wax paper just fine.
Users browsing this forum: malcolmw and 206 guests
