Repairing Workshop Tools/ Machines?
needsmorecowbel
Post by needsmorecowbel » Thu Jan 27, 2011 9:15 pm
Hey guys i picked up a tasty Belt Sander Disk Sander combo with a busted (burnt out) motor today for the cheeky price of $0.00...Has anyone ever looked into motor reconditioning for their damaged or busted machinery (that is assuming that their machinery has broken down)? Or even just replacing motors...is it very cost effective?
http://home.comcast.net/~kvaughn65/disc_belt.jpg
Cheers, Happy belated Australia Day
Stu
Re: Repairing Workshop Tools/ Machines?
Post by kiwigeo » Thu Jan 27, 2011 10:02 pm
If the machine cost you nicks then yes its worth investigating.
ozwood
Post by ozwood » Thu Jan 27, 2011 10:16 pm
This might help. http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
a supplier of motors.
Paul .
Puff
Post by Puff » Thu Jan 27, 2011 10:20 pm
The same motor you have is probably in 10,000 plus other machines in Oz from bandsaws through spindle sanders, routers, benchsaws, dropsaws ad infinitum. Google the specs and seek.
They're only worth reco costs if they're kinda wierd specs and your's isn't.
Post by jeffhigh » Fri Jan 28, 2011 6:18 am
When I burned out my bandsaw motor, I found that motor rewinding started at $350, not including dissasenbly or reassembly.
duh Padma
Post by duh Padma » Fri Jan 28, 2011 7:32 am
Well Stu...
Re: them belt sander/disk combos, me got tired or buying a new one every two years but it was cheaper than the replacement motors which cost more than a whole new machines list price....
Must have thrown a few in the dump....
Then one day brilliance struck...me pulled the sanding disk off, slapped on a V pulley and a washing machine motor mounted underneath and have never looked back. My 2 year old Delta sander is starting to show signs of the motor ready to give up the ghost so me gonna do the same thing...Yes two sanders...one in the breakout shop and one in the assembly shop.
blessings
Post by kiwigeo » Fri Jan 28, 2011 8:44 am
If you cant fix the motor theres always this option:
needsmorecowbel
Post by needsmorecowbel » Fri Jan 28, 2011 5:15 pm
The Trade Assistant/ Lackey alternative...But have to make the cage to specs...damn
Post by Taffy Evans » Mon Feb 07, 2011 7:15 pm
This motor on my dust extractor stopped starting on its own a year or so back, start windings I suspect [the switch inside appears ok] so I fitted this pully, start it like my lawn mower, and then push the start button. Cheeper that a new motor or rewind.
Post by Lillian » Mon Feb 07, 2011 11:26 pm
Taffy that's a cool solution, but how did you figure out that it was the start windings and not the motor itself?
WaddyT
Post by WaddyT » Tue Feb 08, 2011 2:12 am
Guess that sort of takes care of the remote start situation! :toi
Waddy
Post by Taffy Evans » Tue Feb 08, 2011 10:36 am
Hi Lillian, when I pushed the red start button the motor just sat there humming, or turned so slow that it eventualy cut out on the protective overload switch. The mechanical switch in the motor that makes contact with the 'run' windings when the 'start' windings get the motor up the required speed was working ok, so I suspected the start windings. A layman account.
I remember running my first shop built thickness sander on an evaporative [swamp] cooler two speed motor for ten years, with one speed not working ,so I wired up to the other speed.
Post by Lillian » Tue Feb 08, 2011 2:33 pm
Sounds like the capacitor went bad. Yours is a cool solution, no doubt. And its pretty much kid proof too.
Post by rocket » Tue Feb 08, 2011 4:01 pm
Taff,, Do you wear the same Chinese work boots when you start your lawn mower?
:P :P :P :P Cheers,,,Rod
Post by Taffy Evans » Tue Feb 08, 2011 4:38 pm
Rocket, safety gaurds removed the for clarity.
Post by rocket » Tue Feb 08, 2011 4:50 pm
Yep!
Users browsing this forum: TKAY and 26 guests
