Archtop Back Plate Crack
Post by ozziebluesman » Sun Apr 24, 2011 8:15 pm
Since Christmas I have been working away at an archtop build using the Bendetto book and dvds. The neck is built and the past few days I have been carving the back. The back is now almost a uniform 6mm thick. The wood is some old Queensland Maple and when I cut the shape out on the bandsaw I knew there was a crack and it was going to be an issue in the future.
I can get the crack seperated enough to glue up no problems. Due to no back braces on these guitars do I need to patch the crack on the inside? Also would hide glue be a better choice than titebond to repair the crack?
Here are two pictures
Thanks for your attention
matthew
Re: Archtop Back Plate Crack
Post by matthew » Sun Apr 24, 2011 9:20 pm
I think, if you can glue that up with good hide glue and clamp so that the crack is all but invisible, then you will need to do nothing more.
You might need to tack on some clamping turrets either side of the crack to pull the crack closed. But perhaps you have a better clamping method. Mine is below:
yeah that's PVC pipe with a bolt through it. puts the clamping pressure right where you need it.
Bruce McC
Post by Bruce McC » Sun Apr 24, 2011 9:44 pm
The heretics solution would be to clamp the back to close the
crack then use a thin super glue.
Bruce Mc.
Post by Kim » Sun Apr 24, 2011 10:00 pm
I agree completely with Matthew on this repair. HHG is perfect in this this application, stronger than the wood itself and if clamped well its transparent nature means that the joint will all but disappear.
Post by ozziebluesman » Sun Apr 24, 2011 10:33 pm
Thanks Bruce for your thoughts but I agree with Mathew and Kim the HHG is the way to go. I will endevour to glue this crack up tomorrow and will post a picture.
vandenboom
Post by vandenboom » Mon Apr 25, 2011 10:24 pm
matthew wrote:I think, if you can glue that up with good hide glue and clamp so that the crack is all but invisible, then you will need to do nothing more.
Thanks Matthew, techniques like this are just priceless additions to the list of skills of a mug woodworker!!
Not just the clamps, but the gluing of temporary blocks to enable clamping -- I just love it.
Frank
matthew
Post by matthew » Mon Apr 25, 2011 11:26 pm
vandenboom wrote: Not just the clamps, but the gluing of temporary blocks to enable clamping -- I just love it.
Frank
And if you want to be REALLY clever, you cut lil wedges to slide between the paired turrets in order to correct the angle of clamping ... :wink:
Post by ozziebluesman » Tue Apr 26, 2011 8:25 am
Very simple, well thought out clamping method alright! Thanks Mathew.
Job done with the HHG and some Stew Mac, nice strong sticky tape.
Thanks for your interest.
Clancy
Post by Clancy » Tue Apr 26, 2011 8:46 am
Nice one Alan! :cl :cl
Post by Kim » Tue Apr 26, 2011 9:26 am
ozziebluesman wrote: Job done with the HHG and some Stew Mac, nice strong sticky tape.
What job? :wink:
Bruce McC
Post by Bruce McC » Tue Apr 26, 2011 10:05 am
Great job Alan, must try this new HHG stuff one day :wink:
Bruce Mc.
Post by Nick » Tue Apr 26, 2011 11:34 am
Nice catch Alan :cl
You'd almost never know except you've told us :wink: . :)
afshar wrote:Great job Alan, must try this new HHG stuff one day :wink:
Baa humbug, new fangled technology, it'll never catch on.
liam_fnq
Post by liam_fnq » Tue Apr 26, 2011 11:53 am
Simple fix with perfect results. well done. :cl
Post by kiwigeo » Wed Apr 27, 2011 12:12 pm
Kim wrote: What job? :wink:
Yay.....he filled his crack with hide glue! :shock:
Post by Nick » Wed Apr 27, 2011 1:27 pm
This isn't a commisioned build for a plumber is it Alan? :lol:
Post by ozziebluesman » Wed Apr 27, 2011 1:44 pm
Sorry Nick, I won't be trying to repair that one but you know my crack repair was absolutely painless!
:lol:
Users browsing this forum: Google and 121 guests
