Best chisels for lutherie?
Post by Mark McLean » Thu Sep 29, 2011 7:06 am
I have been carving braces with a set of Irwin general woodworking chisels that I got from Bunning's. They get the job done, but they are not ideal. So now I have been looking around E-Bay for vintage chisels that might be good for the job - as well as having good workshop mojo. What should I look out for? What is your favourite chisel(s) for lutherie purposes?
Clancy
Re: Best chisels for lutherie?
Post by Clancy » Thu Sep 29, 2011 8:37 am
I've got a bunch of titans gleaned from ebay.
They tend to be the ratiest ones as they're the cheapest, but I don't mind spending the time to flatten the backs and re-create the cutting edges (I don't mind the pitting & such on the fronts so I tend to just give them a light clean)
It's a cheaper way to get reasonable chisels, just make sure there's still plenty of length in them.
Titan front.jpg (38.29 KiB) Viewed 8582 times
Titan back.jpg (50.76 KiB) Viewed 8582 times
To be honest though, the chisel I use the most (apart from the 1/8 Titan) is a 3/4" Union Hardware set up as per Kim's brace shaving chisel in this thread (don't drool on your screen as you scroll past Michael's chisels :D )
viewtopic.php?f=1&t=2518&p=30832&hilit= ... orn#p30832
Union Front.jpg (28.54 KiB) Viewed 8582 times
Union back.jpg (24.18 KiB) Viewed 8582 times
I use it on everything, not just for shaving braces, and get's my "Two Thumbs Up"
Post by woodrat » Thu Sep 29, 2011 9:41 am
Hi Mark, my Go To chisel is an 18mm wide, long handle Japanese paring chisel. I have had it for 14 years so it is only about 1/2 its original blade length now. The balance of them is exceptional especially for brace carving. Beautiful steel too.
Post by Dominic » Thu Sep 29, 2011 5:56 pm
I am not sure there are chisels that are only good for lutherie. Any good chisel will be good for making guitars. The only issues is getting the sizes you need.
I have stuffed around with 3 LMI chisels for ages and have always had trouble with the blades bending over even with soft spruce after very little use. This is with a 25/28 bevel combo.
I recently bought a 25mm LN bevel edged socket chisel and it is fantastic. Holds a beautiful edge and has enough mass to assist control. I love it and I'll get a few more to replace my narrower LMI ones.
Post by Mark McLean » Thu Sep 29, 2011 9:33 pm
Craig, thanks for the reminder about the "chisel porn" thread. I now remember seeing it before but it had slipped my mind. You have both given me a few good pointers about what to look out for in used chisels and I have put a few speculative bids out on E-Bay. I'll see how that works out. Compulsive TAS is starting to set in - but I can justify it as I have a "zero birthday" looming, just like our esteemed PM.
Nick Payne
Post by Nick Payne » Sun Oct 02, 2011 5:44 pm
Last time I visited my brother in Switzerland I bought myself a set of Pfeil short butt chisels. Being so short in both the handle and blade I find them very good for small delicate jobs. They're only about 150mm long including the handle. These are the chisels: http://www.pfeiltools.com/en/products/c ... h-4er.html.
I'm pretty sure that Carbatec sells them, but I don't know what they charge.
Users browsing this forum: No registered users and 122 guests
