I wonder
I wonder
Hey this is a pretty looking guitar. Its suffering from a little bit of bridge tilt
Whats that black thing around the bridge
- 1 Looks nice.jpg (187.27 KiB) Viewed 19931 times
Re: I wonder
Had a repair maybe
- 2. closer inspection.jpg (178.96 KiB) Viewed 19923 times
Re: I wonder
Really we should have a better look
- 4. What the.jpg (194.2 KiB) Viewed 19923 times
Re: I wonder
You have got to wonder what sort of nasty hardware is being hidden under those three MOP dots? This thing has really had its face punched in at some stage.
Re: I wonder
You asked and I shall deliver
- 6 You gotta be kidding me.jpg (171.12 KiB) Viewed 19910 times
Re: I wonder
I'd say it's a sound enhancer!Mark McLean wrote:You have got to wonder what sort of nasty hardware is being hidden under those three MOP dots?
Re: I wonder
mmm, houston there is a problem
- 7 Houston we have a problem.jpg (188.59 KiB) Viewed 19906 times
Re: I wonder
Oh, there is nothing (where the bridge was). I am sure that being a (even though self declared?) "Master of nothing" you will master this!
Re: I wonder
I can only imagine with amusement , the thought process behing that initial "repair" , Bridge lift's after going for the next Octave on every string , whilst using 13 - 56 strings , bridge meets Nut , owner says I get Johno to take a look he knows a guy , who drinks with a bloke that once watched a guy change some strings so he knows all about guitars , and besides he's a Plumber , Johno takes a look , gets out the stanley knife , says what this needs is some reinforcment , got some 12mm ply I use under dunnies , we'll sikaflex that in, she will be right , and then we can cover that excess sikaflex with some plastic off that old lawn mower catcher over there , Proper JOB !!!!!!!!!!!!
Paul .
- woodrat
Re: I wonder
Gotta love that Australian Can Do attitude!ozwood wrote:I can only imagine with amusement , the thought process behing that initial "repair" , Bridge lift's after going for the next Octave on every string , whilst using 13 - 56 strings , bridge meets Nut , owner says I get Johno to take a look he knows a guy , who drinks with a bloke that once watched a guy change some strings so he knows all about guitars , and besides he's a Plumber , Johno takes a look , gets out the stanley knife , says what this needs is some reinforcment , got some 12mm ply I use under dunnies , we'll sikaflex that in, she will be right , and then we can cover that excess sikaflex with some plastic off that old lawn mower catcher over there , Proper JOB !!!!!!!!!!!!![]()
Re: I wonder
It's just a slightly enlarged Maton pickup hole isn't it. No problem.
Re: I wonder
Think you've found the cause of the bridge tilt Steve. Not sure it'll buff out though
Re: I wonder
Reminds me on:
"I'm fixing a hole where the rain gets in - and stops my mind from wandering [...]"
Remember?
Remember?
- needsmorecowbel
Re: I wonder
If Sikaflex can't fix it then get out the licky nails
Re: I wonder
I actually know the guy personally. Hes a really nice bloke, definetly the aussie give it a go type.
Hes tried but was not getting anywhere as you can see. (2k tanglewood), but hey its his guitar.
I explain to a lot of people when it comes down to luthier work, its not having tools that makes the difference, but respect for the wood. Most things can be done with a hot knife / scraper and some sand paper
You can see here the different types of braces hes put underneath, but the fact hes cut the old braces off to put them in and then the old braces were not attached properly doesnt help either.
It will be purty again
- 9 what happened to the barces.jpg (168.23 KiB) Viewed 19818 times
Re: I wonder
Thats a bloody disgrace and as the scots say "tha should nay mess aroond with something tha ken nuthin aboot"
Re: I wonder
Looks like he has something against rosewood bridge patches as well. "Who the hell put that bit of brown wood on there? I don't want it there messing up the nice white wood of the top. I'll just hack it off with me trusty butter knife and an old screw driver"
Re: I wonder
The "Tanglewood" inlay on the headstock needs some work....should read "Manglewood".
- woodrat
Re: I wonder
kiwigeo wrote:The "Tanglewood" inlay on the headstock needs some work....should read "Manglewood".
Re: I wonder
I find it interesting to get a look at the top bracing (what's left of it) in a mass produced guitar. Common approach re layout and scalloping, but assuming braces are q/s and reasonably stiff, they still have a fair bit of meat on them - the safe approach in a mass produced setting.
