Stiff Grover Machine head
vandenboom
Post by vandenboom » Mon Dec 19, 2011 2:07 pm
I have a 1974 Martin D28 that I have had for a long time. I don't play it at all these days. One of the machine heads (Grover) has gone very stiff.
Are these serviceable? If not, can you replace one, or should you replace the lot? If replacing, any suggestions on suppliers.
Thanks. Frank.
Shane Woonton
Re: Stiff Grover Machine head
Post by Shane Woonton » Mon Dec 19, 2011 2:19 pm
Hi Frank, Stewmac will supply one-offs if you request them by email. They don't have costs on the website. I had to replace a similar tuner late last year.
Shane
John Maddison
Post by John Maddison » Mon Dec 19, 2011 8:43 pm
Try untying the string from the post, then give the post & shaft a few squirts with Inox (the 'Supreme Lubricant' - comes with a thin plastic tube that fits in the nozzle for fine spraying) then give the tuner a few vigorous turns:
Failing that check with your local music shops to see if they have any second-hand tuners available that match your Grovers. One of our local stores which takes on repairs keeps a box of sundry guitar bits & pieces under the counter, which has been a great source of spare parts.
John M
Online
Post by kiwigeo » Mon Dec 19, 2011 9:56 pm
Frank,
Will is about to put in an order to Stewmac and has offered to include others' requirements in his order:
viewtopic.php?f=23&t=3898
Post by charangohabsburg » Tue Dec 20, 2011 2:52 am
Crafty Fox
Post by Crafty Fox » Thu Dec 22, 2011 8:52 pm
Ah, she's stuffed, mate. Best you just send that old D28 over to me! No, but seriously, as I understand it Grovers offer a 'Lifetime' warranty on their tuners. At least they do nowadays. Maybe you can contact them and find out? You might get a free replacement. They look like Rotomatics to me.
Cheers.
Ken
vandenboom
Post by vandenboom » Fri Dec 23, 2011 8:06 am
Thanks everyone. Lubricant has made it quite usable again. They are sealed units so I couldn't inspect the gear. In the process I have found out they are Grover 102's (rotomatics, 14:1), and I can replace the whole set for $60-$100. Frank
Post by charangohabsburg » Fri Dec 23, 2011 8:26 am
vandenboom wrote:They are sealed units so I couldn't inspect the gear.
So there is no tuner button screw as described by Frank Ford on frets.com?
vandenboom
Post by vandenboom » Sat Dec 24, 2011 8:36 am
The screw was there (flat blade). I removed it but the peg would not slide out.
When I took it to the repair shop (Real Guitars - Brendan Mason - very experienced), the chap tried reducing the stiffness by adjusting that screw, so the screw seems to have some impact on this as well. He certainly did not try to remove the peg.
Frank
ozwood
Post by ozwood » Tue Dec 27, 2011 7:47 am
Paul .
68matts
Post by 68matts » Tue Dec 27, 2011 10:51 am
I got a set of these a few weeks ago. I bid around $11-$12 I can't remember exactly and was outbit but got a second chance offer to buy them for the starting price.
They seem to be genuine and shipping was pretty fast aswell.
http://www.ebay.com.au/itm/3L-3R-Grover ... 935wt_1396
I don't know if that link will work I've never tried doing that before, if it doesn't the sellers id is
dingding747627 you could just do a search for that.
Matt
Users browsing this forum: Joshyouare and 173 guests
