Show us your shop and what your doing.
Post by Allen » Sun Feb 03, 2008 5:23 pm
Since Hesh likes to show off his obsessive, compulsive clean fetish, and I broke down and had a major clean up of the garage, this is probably one of my only chances to show off my work space without it looking like a bomb went off in it. I like a clean shop, it's just not my priority. :lol:
I did get a little building done this weekend as well. I managed to finish a neck and get a coat of epoxy filler on it.
And braced, voiced and glued up a top.
This is an Engelman top and it comes in at 195 grams. 2.8 mm thick at the bridge and down to 2.6 around the lower bout. Bracing started out at 7 X 13 mm and shaped from there.
The yellow/orange streaking on the top is just a wash coat of shellac. I haven't decided if I'll give it a nice even coloring of this, or bring it back to the white base color. I haven't decided on binding yet, so it all a bit up in the air.
Post by Craig » Sun Feb 03, 2008 9:17 pm
I'd call that a neat workshop Allen. All fairly organised and tons of room. Like the bike too !
In my opinion , a dark shellac will really suit that guitar . Goes with that beautiful rosette . That's going to be a striking guitar .
Fantastic work all round mate . Spotted the bottle of Bourbon too :wink: :lol:
Not much bench work I can show at the moment , but here are a couple of shots of my workshop I took some time ago . It is within our house , so can easily slip in given a spare moment.
And some of the view outside my workshop windows ;
Cheers, Craig
Dave White
Post by Dave White » Mon Feb 04, 2008 6:28 am
Allen,
Nice workshop!! Is the motorbike part of your dust extraction system? :D
Nice work going on there too.
Nice views Craig.
Dave White
matthew
Post by matthew » Mon Feb 04, 2008 10:32 pm
Workshop today: Humidity close to 94%. That's sort of why I'm not gluing up the bass.
View from the Window ... inner suburban Sydney
What I am working on now - restoring a rustic (and rusty) indonesian harp/zither (celempung, cetar). a real home-made instrument painted in thick brown fence paint, nailed and screwed together with tin strapping for good measure.
I was asked to replace the pin block, the old pin block was either seized or the pins (rusty motorbike bike spokes) just spen in their holes.
Well, when I got the pin bock off ... well, the only way to get it off was to cut it off, and with it the 12mm plywood soundboard. So then I had to replace the soundboard.
The old soundboard was 12mm ply, with two backing pieces glued to the sides. I figured this was WAY over engineered, couldn't possibly vibrate, so I chopped out the backing pieces and braced the two sides from collapsing towards the centre with a bit of 2x1 pine.
Then I cut a lovely new cheap and cheerful soundboard from a piece of 4mm plywood and invented my own bracing design. And added a radical soundhole. Added "blocks" at top and bottom of the case, banged in the broken-off nails so I can have a glueing surface.
I'll glue the soundboard back on (radical) and screw the pin-block into the bottom block (radical) and restring the thing (using the original bicycle brake-cable strings). Using my (radical) silky-oak bridge and the original bridge wire (bent coathanger).
You can sort of see how it goes together in the first pic
It might work, there again it might collapse. Who knows? WHEEEEE!!!!
I should not have taken this job. It would have been quicker to make a completely new instrument.
[/img]
Post by Hesh1956 » Tue Feb 05, 2008 4:38 am
I took a week off from building to do the final set-up on the SJ I showed in another thread.
But here is a shot of my shop, messy as it is, at the moment.
Post by Allen » Tue Feb 05, 2008 6:33 am
Hesh, the workshop looks great, but I don't see any room for the motorbike? Whats with that?
Great looking workspaces guys.
Sam Price
Post by Sam Price » Tue Feb 05, 2008 7:45 am
great pics, and nice to see all that greenery...long time since I've seen leaves on the trees..........
Online
Post by kiwigeo » Tue Feb 05, 2008 8:04 am
Pics of my shop...not that its getting much use at the moment.
Post by Hesh1956 » Tue Feb 05, 2008 10:46 am
Sam Price wrote:great pics, and nice to see all that greenery...long time since I've seen leaves on the trees..........
Me too Sam and I am appreciating this too.
Allen your shop looks pretty spotless to me - want a referral to a shrink? :D
Matthew's shop looks like a great space to spend time in.
In fact all of the shops pictured look much cleaner and better laid out then most of the shops I have seen elsewhere.
Good going guys.
Post by Lillian » Tue Feb 05, 2008 2:28 pm
Craig, any houses for sale in your neck of the woods?
Post by Allen » Tue Feb 05, 2008 5:02 pm
It's only that clean 'cause the missus spit the dummy and I had to knuckle down and give it about 5 hours of a tidy up. She even made me vacuum...what's it coming to when a fella has to vacuum his shed :?:
Dave White
Post by Dave White » Tue Feb 05, 2008 7:07 pm
Allen wrote:...what's it coming to when a fella has to vacuum his shed :?:
Is that an Ozzie euphamism?
Dave White
Post by Craig » Tue Feb 05, 2008 10:10 pm
G'day Lillian,
There aren't many houses in my neck of the woods, but send me all your money and I'll see what I can do . 8) :wink: ( Meeting up with Kim in Borneo :dru ) :lol:
Cheers ,Craig
Post by Lillian » Tue Feb 05, 2008 11:47 pm
:rolf
Aah, sure, you can be our agent.
Be willing to help us immigrate too?
Post by Allen » Wed Feb 06, 2008 6:44 am
You bet, and I think it's a pretty accurate and funny one.
