Finish sanding schedule..
Re: Finish sanding schedule..
Post by kiwigeo » Mon Jun 18, 2012 12:09 pm
Ormsby Guitars wrote:
kiwigeo wrote:The only time when you should go finer than 320 grit is when you're polishing a turd. :mrgreen:
Obviously I must be polishing turds...
You obviously have a very good marketing department then.. :D
Ormsby Guitars
Post by Ormsby Guitars » Mon Jun 18, 2012 12:15 pm
I put heroine in the lacquer. Every client comes back for more.
MBP
Post by MBP » Mon Jun 18, 2012 6:42 pm
Ormsby Guitars wrote: I put heroine in the lacquer. Every client comes back for more.
Catwoman? Heroin may be more addictive although Halle Berry did play catwoman.
For those interested I picked up 20L of 100% IMS for $80. I think the standard stuff is about $60 for 20L so not bad at all.
What grit do most manufactures recommend before applying finish
