This morning when I was preparing I thought I would browse youtube and get a few different perspectives on it. I came across this video. It made me feel a whole lot my comfortable with my process
youtu.be/
A true master of his craftTod Gilding wrote:I love watching master tradesman at work
Like I said steve, I have no issue with fitting a pre-fretted board at all...most times 'no' levelling is required ....none at all, just a crown and polish and there done, level as they will ever be so you can set the action where you like. When hammering frets over a spruce soundboard there's always going to be potential for a mishap and I simply don't see the need to be shocking glue joints etc with the impact of hammering frets when you don't need to do it that way. But at the end of the day it's whatever works for you that's best for you. What works just fine for me and plenty of other builders, some with literally hundreds of instruments under their belt, is to fret the board off the guitar. Must ask...have you ever tried or is your belief based upon assumption??simso wrote: I believe even with a perfectly flat neck surface a perfectly flat fretboard then fretted and attached together will not give a perfectly flat final product. IMO you will have to file some frets to much to get a good end result
I run a bead of Titebond along tang of my frets prior to hammering them in....but I fret with the fretboard on the guitar.auscab wrote:Kim or Jeff, or any of the, “fret the board off the neck builders/ repairers”
Do any of you glue in the frets as well?
My process is to start with a dead flat board. It is then slotted on a TS and the radius milled via a router jig. The tapper is cut and the board fretted and left to sit overnight, or longer if required, suspended frets up between two smallish blocks (hight of the blocks is determined by hardness of wood the FB is made from, but generally around 13mm) with a gobar placed at the centre to provide app 8 to 10lb pressure loading the board into relief, and pushing it down to the deck surface. This removes the back bow and compresses the wood in the fret slots into the tang of the wire.MBP wrote:If fretting off the neck how do you go with glueing. The board would be bowed a little bit, I just wonder if you then level it (the bottom of the fret board) or just clamp it all down.
Kim, do you glue the board to a fully shaped/sized neck or glue it and then shape/size the neck?
Do you leave two frets out for positioning or is there another way?
Thanks,
Rob,auscab wrote:Kim or Jeff, or any of the, “fret the board off the neck builders/ repairers”
+1 on Titebond on the tang and running a triangle file over the slot before fretting. I also run a dampened cotton bud along the slot to swell the wood a bit and aid in gripping the tang.Kim wrote:Rob,auscab wrote:Kim or Jeff, or any of the, “fret the board off the neck builders/ repairers”
I use to, and sometimes still do use TB when installing frets (depends on the wood). I see it more as a lube to assist pressing but it also helps getting the frets back out down the track because it helps prevent breakout around the slot, not as much as a well ground set of end nippers will but together with a bit of heat on the fret first from a soldering iron, I hardly ever have a problem with tear out. That said, I now wick in CA once the board is on and TR has been loaded just a 'touch'. Oh and by the way, prior to fretting don't forget to relieve the fret slots with a small triangular file so they accept the flair of the tang where it meets the underside of the crown. This will ensure the frets sit down on the board like they are meant to all nice and flush.
Ahh but gibson have recitified that problem, didnt you know they now plek the guitars (loose frets , warped board doesnt matter) just plek it flatOrmsby Guitars wrote:ONE large scale manufacturer frets their boards prior to gluing. They are Gibson. That fact alone makes me want to do it the other way.
Totally weird vid!BBk wrote:I came across this video.
That's a good tip, I use Titebond too but always shove it in the slot with a small knife before pressing the fret, it makes a mess of glue on the fingerboard which always needs cleaning, I should've thought of just sticking it on the fret tang before, you've just made my life a lot easierkiwigeo wrote: I run a bead of Titebond along tang of my frets prior to hammering them in....but I fret with the fretboard on the guitar.
Users browsing this forum: Google and 124 guests
