Help with analysis
weslewis
Help with analysis
Post by weslewis » Mon Sep 03, 2012 12:09 pm
this is a top with bracing inspired by the Gore Gilet books...I will post a pic from my pc shortly, on my laptop at the moment, New to this VA program...
weslewis
Re: Help with analysis
Post by weslewis » Mon Sep 03, 2012 12:16 pm
here is the bracing layout
luke_lee
Post by luke_lee » Mon Sep 03, 2012 5:59 pm
Hi,
Is this the frequency responce for the finished guitar including the bridge? What type of guitar, steelstring classical? Also the white number are hard to read.
Luke
Post by kiwigeo » Mon Sep 03, 2012 6:52 pm
LUKE_LEE wrote:Hi,
Luke
Bridge patch shape suggests its a steel string. Circa 100Hz peak looks like an air resonance peak so this would suggest the top is on the guitar when analysis done.
weslewis
Post by weslewis » Mon Sep 03, 2012 9:05 pm
finished steel string guitar, strung up
DSC00365 (426x640).jpg (193.07 KiB) Viewed 10698 times
weslewis
Post by weslewis » Mon Sep 03, 2012 9:08 pm
numbers are 103 , 185, 194 ,218 , 244 , 283, 327 , 389 , 456
Post by woodrat » Tue Sep 04, 2012 8:55 am
weslewis wrote:numbers are 103 , 185, 194 ,218 , 244 , 283, 327 , 389 , 456
Hi Wes...did you put the side weight attachment points in to trim body resonances? Your 185 needs to go down 5 Hz to start with and side weight is an easy and effective way to do it. I put them in all my guitars now.
Post by kiwigeo » Tue Sep 04, 2012 9:03 am
Wes have you done any Chladni testing? Im currently in the process of doing same on my falcate classical.....the discussion may be of use to you.
weslewis
Post by weslewis » Tue Sep 04, 2012 9:26 am
not yet, guitar has been finished for several months and sounds really good, prototype design i have another in process with falcate bracing so i can compare
Users browsing this forum: Google and 70 guests
