Here's a picture with a neck to give you a sense of scale.
And a close up to show you the cut. Fine on the left, coarse on the right.
Routing will give the cleanest straighest cut. I do it bhy hand, rough cutting with a coping saw and then finishing off with a very sharp paring chisel and then a wide sanding stick. I try and work with the headstock at eye height in my parrot vice so I can quickly see both sides of the headstock. The rounded upper end of my slots get rough worked witha rat tail file and then I finish off with sandpaper wrapped around an appropriate diameter piece of dowel. The square end of the slot gets done with paring chisels of an appropriate width and then finished off with sanding sticks.Allen wrote:Thats good to know Martin, I was thinking that these might be ideal for that. I'll have to rethink this then.
This little size 5 that I'm going to building next is going to have a slotted head stock. I really like the look of the top of the slot being square, rather than the round left by a router bit. Any suggestions on the best way to tackle this?
Users browsing this forum: No registered users and 95 guests
