- IMG_1979.JPG (155.17 KiB) Viewed 11396 times
Cheers,,
Good idea Rod. I'm in Wellington NZ. I do have a mate with a workshop where I could do the sharpening but I don't think it would be ideal having to drive to his place every time I wanted to sharpen my scraper.... How often are you sharpening yours?rocket wrote:Shane they definitely need to be hollow ground so that really means using a grinding wheel with the rest set perpendicular to the contact point of the wheel, Stumc do have a vid of the sharpening process. If you don't have room for a fairdinkum bench grinder i'm sure you could find a drill attachment setup at Bunnys that you could improvise with. BTW what part of the country are you situated?one of the members might be able to help you out!![]()
That is good news. I think that little piece of news may have just pushed it onto the "must have" list. Thanks Rod.rocket wrote:I've sharpened this once only, after arching a maple back it still has a good edge to work with.
On another forum (here) Alan Carruth wrote that he uses a bench grinder "because he has one", and you could create the cutting burrs also with a flat sharpening stone but that a hollow ground edge would help to maintain the angle when honing. (I have never tried sharpening that style of scraper without a bench grinder though - why should I if I have onerocket wrote:Shane they definitely need to be hollow ground so that really means using a grinding wheel with [...]
Users browsing this forum: No registered users and 185 guests
