Maton AP5 pickup
christian
Maton AP5 pickup
Post by christian » Wed May 22, 2013 1:06 pm
Hi,
Has any one out there installed a Maton AP5 pickup? and know where I might be able to purchase one?
I have a customer who is requesting one, and I know little or anything about them. Any help would be greatly appreciated.
Christian.
Leonardo da Vinci
www.christiandruery.com
Dekka
Re: Maton AP5 pickup
Post by Dekka » Wed May 22, 2013 2:36 pm
I am definitely not a fan of Maton's AP5. Their components are inconsistent in quality resulting in some pickups producing a low level hum. I sent two otherwise OK guitars back to them for this reason. However, if your client is after a pickup that will hum along to the music then that's the one to get.
ozwood
Post by ozwood » Wed May 22, 2013 4:01 pm
Hi Christian,
They are only available from maton, you will need to turn your top into swiss cheese to install it , they are know as a palathelic Pickup, I suspect Dekka might have another name for them .
As Dekka said they can be inconsitant , and when they go wrong can be a bitch to get balanced and working properly, talk him into something else , K&K or BBand or a Fishman.
See pic below.
ap5 2.jpg (5.32 KiB) Viewed 12846 times
Paul .
Post by Taffy Evans » Wed May 22, 2013 4:44 pm
I agree, something like this. Causes weak and often "bellied" top.
christian
Post by christian » Thu May 23, 2013 5:21 pm
Thanks for the valuable info guys!!
I can't get over that huge slot cut in the top. I gotta say i'm a little worried about these. Especially if it needs fine tuning because my building style isn't the most practical for adjustments.
Thanks again.
Christian
Leonardo da Vinci
Post by charangohabsburg » Thu May 23, 2013 10:00 pm
christian wrote:I can't get over that huge slot cut in the top. I gotta say i'm a little worried about these.
I reckon that if you make the top 50% thicker you'll be just fine... :mrgreen:
christian
Post by christian » Fri May 24, 2013 5:30 am
hahaha, perhaps a slither or two of CF won't go a miss.
Christian.
Leonardo da Vinci
Post by kiwigeo » Fri May 24, 2013 12:53 pm
Tell your client to man up and install a K and K system.
Users browsing this forum: No registered users and 88 guests
