Hello all,
I live in the northern US, and it's wintertime here.
I have a bunch of bodies and necks here that all need to be finished, I don't want to heat my whole shop for the whole winter just to dry lacquer, and the wife says I can't 'nitro paint' in the house.
I'm thinking about making some kind of box with a heater and thermostat inside it that I can run 24/7 and put finished parts in to dry.
Have any of you made something like this, how did you do it, and how did it work?
Thank you,
ken
Lacquer drying box for cold climates?
Re: Lacquer drying box for cold climates?
In winter I use heat lamps.
I find they're too hot to use during the entire spray session, so I turn them on for about half an hour to an hour after the last coat.
I've also found I need the heat lamps about a meter away from the guitar as otherwise they can get too hot
I find this is enough and then I can turn them off and leave the guitars hanging.
This is in a small 3m X 4m room I built in my workshop.
Trial and error to suit your own situation
