http://www.ebay.com.au/itm/Luthiers-Cir ... 7675.l2557
I just bought it on eBay. My compulsive tool and wood buying habit is acting up
Thanks Martin,kiwigeo wrote:No experience with this circle cutter but I have the Stewmac jig that does the same job. The jig itself will be fine being a Schneider creation but the problem for me is the Dremels...IMHO theyre useless for anything other than very light duty cuts (ie inlay work).....the Dremel is underpowered for anything else and generally the bearing play on the modern machines is too much for my liking. For cutting rosettes I use a stock standard (Trend T5) router with spiral cutter and a router circle cutting jig.
I agree, works well for me.[I've got one of Micheal Connors rosette and circle cutters, and it's a joy to use. You can cleanly score any line (inside or outside), and also remove waste. Easy to set up and repeat too. And it's a handtool, no batteries required!
+1Bruce McC wrote:[I've got one of Micheal Connors rosette and circle cutters, and it's a joy to use. You can cleanly score any line (inside or outside), and also remove waste. Easy to set up and repeat too. And it's a handtool, no batteries required!
/quote]
Users browsing this forum: No registered users and 123 guests
