Wiring help.
nnickusa
Wiring help.
Post by nnickusa » Sun Jan 26, 2014 3:58 pm
I've got a question for the electric guys. I've made a tele-style guitar, and am happy with it, but am having troubles wiring it up. I'm using a 4-way switch, and have added the ground to the cover on the neck, as described. Here's the schematic.....
The problem is, when wired up as shown, I have no neck pickup. The bridge sounds when in the 3rd and 4th position(both Pups at once, but no neck) The bridge does NOT sound when in the second position(bridge alone), nor does the neck sound in any position. Oddly, the bridge sounds when the switch is halfway between the 1st and 2nd positions.....
I do get resistance readings from both up to the switch, it seems to me.
Help? Anyone? Hello?
FWIW, the bridge sounds good..... :roll:
Re: Wiring help.
Post by simso » Sun Jan 26, 2014 4:18 pm
Electrics are pretty simple, first thing throw away the schematic supplied, you need to learn how toi do it from scratch with whats supplied
Step 1 disconnect all wires from the 4 way switch
Step 2 write down what you want each switch position to do - seriously write it down
Step 3 Use a multimeter to identify what cicuits are connected on the switch in each position - again write it down
Step 4 connect the bridge pickup to the position thats just meant to be bridge
Step 5 connect the neck pickup to just the position thats meant to be neck
Step 6 connect the output line from the switch to you volume pot
Step 7 ensure that in the two nominated positions you are oututting to the amp, just touch the pickups with a scvrewdriver to check
Step 8 Using the diagrams you drew above jumper a wire from the neck to the next switch potions its required on, do the same for the bridge
No more steps - its working
Re: Wiring help.
Post by simso » Sun Jan 26, 2014 4:22 pm
If all thats too complicated then just write what you want each switch position to do, and show me the multimeter settings of the switch, and Ill draw it up for you, again forget the diagrams use a multimeter to map it out
nnickusa
Re: Wiring help.
Post by nnickusa » Sun Jan 26, 2014 6:50 pm
OK, Steve. I'll do that tomorrow. When my head gets done in, I leave it for another day. Just spent the arvo at the beach with my beautiful wife sharing a bottle of the bubbly.... :)
Tod Gilding
Re: Wiring help.
Post by Tod Gilding » Sun Jan 26, 2014 7:37 pm
+1 What Steve Said, Great advice already given. this is how I do it ...NOW :roll:
Re: Wiring help.
Post by jeffhigh » Sun Jan 26, 2014 8:52 pm
it's a little more complicated with the 4 way, with the 4th position intended to produce series with both pickups.
In the neck only position and neck/bridge parallel position you need to have the neck ground pass through the switch and earth on the back of the pot. Follow that through with the multimeter and make sure it is happening
That will get you the three standard tele positions.
Then in the neck/ bridge parallel position you need the neck ground connected to the bridge hot but not to ground and at the same time the neck hot through the switch to the input lug on the pot
Re: Wiring help.
Post by simso » Sun Jan 26, 2014 9:06 pm
I agree,
Doing it the way explained will teach nick how to do it on all future builds, as far as the 4th being a series link, it just means we cut the earth and link it through the switch, not a biggie,
Re: Wiring help.
Post by jeffhigh » Sun Jan 26, 2014 9:22 pm
No Biggie but it needs to be mentioned because if that earth is not connected properly you won't have a functional neck pickup.
I always work though it in the method you suggested cause I never trust the switch to work in the same way as the diagram, but in this case you need to be allowing for the neck ground as well as just the hot lead.
Your step 6 only allows for connecting the output terminal from the switch to the input lug on the pot and not the switched ground to the back of the pot
Re: Wiring help.
Post by simso » Sun Jan 26, 2014 9:46 pm
The steps are merely to get both pickups working in the standard positions, I teach guitar building and wiring.
Once it is established that both pickups work and that volume/ tone pots also work, I then get the guys to bring in the alternative wirings, the alternative wirings are simply loops and splits.
To the person that already knows wiring it appears to be the long way round, but to someone who's learning it suddenly makes se seas you do it
Re: Wiring help.
Post by jeffhigh » Mon Jan 27, 2014 4:10 am
Also worth checking the resistance of the neck pickup between hot and ground leads to make sure nothing has been dislodged when the earth to the pickup cover was cut.
Dekka
Re: Wiring help.
Post by Dekka » Mon Jan 27, 2014 8:01 am
Hi, Nick.
I have found it a help to have a visual aid to help get my easily distracted brain around switches.
Most likely is a short where you disconnected and reconnected the neck cover ground. other than that I'd look for a blob between switch lugs.
Just print this and draw your wiring over the positions that aren't working and it will become apparent if the jumpers are incorrectly placed. Hope this helps.
Re: Wiring help.
Post by jeffhigh » Mon Jan 27, 2014 8:39 am
Great animation Dekka!!
The neck pickup is switched on the ground rather than the hot, that's the key.
Re: Wiring help.
Post by simso » Mon Jan 27, 2014 12:30 pm
Thats a pretty good clip dekka, did you make that one yourself.
Dekka
Re: Wiring help.
Post by Dekka » Mon Jan 27, 2014 1:33 pm
I wish I was that clever. No. I drew the positions diagram but not the animation. I found that years ago on the net when I made my 4way Tele.
nnickusa
Re: Wiring help.
Post by nnickusa » Mon Jan 27, 2014 1:46 pm
Haven't had a chance to work on the switching today, but is there a right and a wrong way for the switch to be oriented? I note that there is always a shadow of the base shown, but the switch looks to be the same on both sides?
Looks like I'll need to wait till tomorrow to have a go. The boss has made plans for us.
Thanks to you all, and Dekka, that starts to make sense...
Dekka
Re: Wiring help.
Post by Dekka » Mon Jan 27, 2014 9:37 pm
So this evening I taught myself how to animate the switch position diagram. It's not so hard after all.
ozwood
Re: Wiring help.
Post by ozwood » Mon Jan 27, 2014 9:58 pm
I'm just concerned :shock: what manner of evil :twisted: and mischeif :mrgreen: your gonna get upto with your newly found skill.
Paul .
Dekka
Re: Wiring help.
Post by Dekka » Mon Jan 27, 2014 10:11 pm
Give me a fortnight and I'll be up to "Avatar" standard. :git ...or at least "Stick figure running." :oops:
Dekka
Re: Wiring help.
Post by Dekka » Tue Jan 28, 2014 5:41 pm
This one shows how the MAGIC MUSIC SMOKE travels through the Series selection to produce uber-tone at the other end. :D
4way Series.gif (577.38 KiB) Viewed 18524 times
Users browsing this forum: No registered users and 169 guests
