Polyester two pack supplier in Australia
Post by simso » Fri Apr 18, 2014 1:04 pm
Guys, we have just recently tooled up for sublimation printing, one of the things that allow a surface to recieve a sublimation print is apparently being coated in a polyester coating with hardener.
Anyone know of a supplier that may be able to supply Polyester two pack
This is not really for guitars as you have to bake the print into the coating at 200 degrees celcius, so in reality it would likely burn or charr the wood surface, its more of a sideline gig for printing on tiles and other stuff
Ideas
demonx
Re: Polyester two pack supplier in Australia
Post by demonx » Sat Apr 19, 2014 2:06 am
I'd call PPG tech support and see what they have.
There's so many different departments to the company from domestic, industrial, auto etc you may get a runaround, but that would be my first place to call.
Ph: 132424 is the number I have recorded, I think that's the direct line to the auto tech support. Can't remember as it's been quite a while since I've needed their help. They should be able to point you in the right direction anyway
Post by jeffhigh » Sat Apr 19, 2014 9:30 am
Would ordinary polyester fibreglass resin work?
Post by simso » Sat Apr 19, 2014 11:22 am
Thanks allan
Jeff, I have no idea either.
Clancy
Post by Clancy » Thu Apr 24, 2014 7:18 pm
'Shapers' supply a version for surfboards, don't know if it's what your after though..
http://www.shapers.com.au/categories/Su ... ter-Resin/
Post by simso » Thu Apr 24, 2014 7:29 pm
Thanks Clancy, there is a company that sells the exact product designed for this purpose overseas, so I have made a purchase with them first to actually see what the product is actually like and how well it works, once I know that it works well, I will try and source a local supplier
Users browsing this forum: Blackstar1099, Mr K and 103 guests
