Laminated Mandolin Neck - Construction Advice
Kim Strode
Post by Kim Strode » Sat Apr 26, 2014 1:25 pm
I want to make a laminated neck for a mandolin, more for aesthetics reasons than strength. I have a piece of quarter sawn Qld Maple large enough to cut out a one piece neck, but I was thinking of adding a thin blackwood stripe down the centre, bordered by maple and black veneer each side of the blackwood (veneer sheets purchased from Australian Luthier Supplies).
I am seeking views on construction and assembly to ensure the end result is strong enough. For example, do I glue all layers in one go, or do I assemble the layers progressively? Also, will the veneer sheets have sufficient bond to provide a strong neck once glued together?
Kim Strode
Daylesford, Australia
Re: Laminated Mandolin Neck - Construction Advice
Post by jeffhigh » Sat Apr 26, 2014 2:41 pm
They say that their black veneer sheets are black dyed maple (not black fibre) so strength wise you should be fine.
I'd be gluing it all up together, which is what I did on my sole laminated neck to date.
Post by simso » Sat Apr 26, 2014 2:58 pm
Glue it all up at once
peter.coombe
Post by peter.coombe » Sat Apr 26, 2014 3:42 pm
Glue all up at once, and so long as the veneer is real wood veneer and not fibre sheets then it should be fine.
Peter
Post by kiwigeo » Sat Apr 26, 2014 7:26 pm
Epoxy?
demonx
Post by demonx » Sat Apr 26, 2014 8:01 pm
I do a lot of laminated necks.
If its only a few pieces, then I just glue and clamp. If it's several pieces, sometimes I do nine piece necks, then I make what I call wood kebabs.
I cut the pieces longer than I need, allowing enough room for a dowel joint at either end. I dryclamp, then drill, then pull it all apart, glue up, I use a roller to roll the glue quick and even, then I simply drop the pieces onto the kebab and then clamp up. The pieces of dowel stop it from wriggling around and it makes a slippery job nice and easy.
I recommend the use of a drum sander to prep the laminates, I see you're local to me so if you don't have one you're welcome to come around.
Exact process I used to do all this:
and the matching fingerboard:
scuffle
Post by scuffle » Sat Apr 26, 2014 8:39 pm
i have made a few laminate necks with veneer accents. I just glued everything at once and used titebond original wood glue. They are very strong necks as well. Takes a bit onger for the truss rod to adjust these ones :)
Flame maple with ebony accents
Not as many layers as Allans but from what you have said you wont have a million pieces like he does :)
Good luck with it. From the description it should look pretty nice!
Andrew Hobson
Kim Strode
Post by Kim Strode » Tue Apr 29, 2014 9:54 am
Thank's to everyone for your advice. Glued up the laminated neck yesterday and took clamps off this morning. Will post pics of finished Mandolin. Thanks Allan for your offer of belt sanding…must drop in to Ballarat and have a chat one day very soon.
Kim Strode
