A pic that Jeremy posted quite a while back caught my attention at the time and I've always wanted to do something similar.
His was a outline with a simple but classy filigree on the 12th fret.
Well, I pinched the filigree concept but put my own touch on the theme. I thought it only fitting as this blank came from Jeremy a couple years ago and I'm only getting a chance to look at it now!
I hope Jeremy doesn't mind:
Re: I hope Jeremy doesn't mind:
A couple more pics
- image.jpg (83.99 KiB) Viewed 7276 times
- image.jpg (82.71 KiB) Viewed 7276 times
That'll look sensational when its finished Allan.
How do you intend filling the channel Allan, Purfling strips, shell or a solid (coloured) epoxy? Certainly will add a touch of class to the fingerboard.
I filled it with maple just after I took those pics. I'll get to sand it back today and see what it looks like.
The colouring turned out very much as I expected, as in its very subtle. On this I was torn between leaving the board blank with no inlay or doing something barely noticeable, anyway, I'm pleased with the result:
- image.jpg (107.12 KiB) Viewed 7122 times
Well, you've seen some of it so I may as well show some more.
Black Walnut "knotty" body
This was a dry fit of the Mahogany, Maple and Walnut neck pieces:
Up to dust stage:
Up to dust stage:
