Number four will be the one!!!!
Yeah a bender and heat blanket would be alot easier but Im determined to do this by hand.....rocket wrote:Sometimes this caper can be very very trying Martin can't it!! Any chance of using a bender and heat source, say, blanket or bulbs ?
Sides are worked down to 1.7-1.8mm around cutaway area.felix wrote:What's the thickness of the sides at the cutaway?
Looks quite thick in those photos.
I work mine down to around 1.6 - 1.8mm in the cutaway area then add 2 small side braces for extra support.
Ohh and obviously soak for an hour in hot water.
Havent broken a side yet. Binding though.....
Thanks Dave....your picture of the pile of mangled maple made me feel alot better....nothing like knowing someone else is having ten times as much trouble bending venetian cutaways as I am.Dave M wrote:
Good luck with your continuing efforts.
Users browsing this forum: No registered users and 139 guests
