Anybody used this stuff?
Post by Nick » Tue Aug 04, 2015 6:30 am
At 5.40 into the vid Eric Coleman uses 'Deglue goo'. I see it has Acetic acid as it's active ingredient, just wondering if any body here has used it and if so, did it do what it says on the tin?
youtu.be/
Re: Anybody used this stuff?
Post by Bob Connor » Tue Aug 04, 2015 7:54 am
I own a bottle of it but have never had to use it Nick.
I seem to remember that Rick Turner swore by it, so I basically bought a bottle on his recommendation.
I believe it works with Titebond and LMI white.
Post by kiwigeo » Tue Aug 04, 2015 11:24 am
Or you could try my new product........"De-F****k It"
Post by charangohabsburg » Tue Aug 04, 2015 7:46 pm
kiwigeo wrote:Or you could try my new product........"De-F****k It"
Martin, you should get into business with the EU-bureaucrats, the ECB and IMF.
Post by Trevor Gore » Wed Aug 05, 2015 10:50 pm
Nick wrote:At 5.40 into the vid Eric Coleman uses 'Deglue goo'. I see it has Acetic acid as it's active ingredient, just wondering if any body here has used it and if so, did it do what it says on the tin?
Acetic acid doesn't appear to be the only active ingredient. I wanted to get rid of some residual Titebond set on the sides of the bottle before I re-used the bottle. I left full strength cleaning vinegar in it for a week. No effect whatsoever!
johnparchem
Post by johnparchem » Thu Aug 06, 2015 4:24 am
I use it to clean up glue around braces or linings. It works great. It jell constancy keeps it in place. I let it sit a few minutes and scrape it off.
Post by Nick » Thu Aug 06, 2015 6:04 am
Trevor Gore wrote:Acetic acid doesn't appear to be the only active ingredient. I wanted to get rid of some residual Titebond set on the sides of the bottle before I re-used the bottle. I left full strength cleaning vinegar in it for a week. No effect whatsoever!
Hmmm thanks Trevor, must be more to this white man's magic! :D
johnparchem wrote:I use it to clean up glue around braces or linings. It works great. It jell constancy keeps it in place. I let it sit a few minutes and scrape it off.
Thanks John, the sort of thing I'm after, would hate to get a bottle all the way back to NZ only to find I've paid for a bottle of expensive snake oil. Do you have to 'wash' any residual off afterwards to stop further reaction or is it an apply once and forget?
johnparchem
Post by johnparchem » Thu Aug 06, 2015 6:24 am
I remove it as part of the clean up process of removing the dissolved glue. I do not really do anything else to neutralize it other than my normal prep. I have never had any issues with it after it dried.
Users browsing this forum: No registered users and 119 guests
