Longest time spent on a dovetail neck joint
Post by kiwigeo » Wed May 07, 2008 6:21 pm
Okay.....its been 3 days now and Im still f***ng around with the dovetail M and T neck joint on the 12 string. Its just like the classic table with the wobbly leg..you adjust the leg you think is the odd one out and end up with a wobble on another leg.
Im spending so much time out in the workshop working on this bldi guitar my wife thinks I have a lover.
matthew
Post by matthew » Wed May 07, 2008 9:58 pm
is it a parallel edged dovetail or tapered?
Post by kiwigeo » Wed May 07, 2008 10:06 pm
matthew wrote:is it a parallel edged dovetail or tapered?
It's the full Monty...ie a double half blind dovetail Mortise and Tenon. I guess that equates to a tapered dovetail in answer to your query.
Im getting there.....getting the hang of this joint is a matter of getting to know your enemy.
WaddyT
Post by WaddyT » Thu May 08, 2008 12:14 am
I did the same thing with a V-Joint on a neck. Tweaked it until it didn't even resemble the original cut. Then I finally got it to fit, glued it up, added the heel stack, had the bright idea to make a sled for cutting the side slots (Spanish Heel - Classical) on a table saw, and buggered it up beyond recognition. Guess I'll be trying another V-Joint.
Waddy
Post by kiwigeo » Thu May 08, 2008 4:41 pm
Some pics of the instrument in question. First pic of the body and neck ready to go. Second pic of the body with one coat of neat Z-poxy finishing resin applied.
matthew
Post by matthew » Thu May 08, 2008 5:36 pm
Fitting the dovetail, do you remove wood from the neck, or the block ... or both?
Post by kiwigeo » Thu May 08, 2008 6:00 pm
I only remove wood from the neck tenon, never the mortise.
matthew
Post by matthew » Thu May 08, 2008 6:08 pm
When fitting a double bass neck, I do the opposite. I only remove wood from the block, not the harder neck tenon itself. The logic is that the block is softer and easier to work.
I use strips of paper coated in chalk slid down along the edges of the mortise when the thing is assembled. I slide out the paper and shave off where the chalk marks the block.
Post by kiwigeo » Thu May 08, 2008 6:31 pm
Working the tenon seems to be the norm in the guitar world. Both the mortise and tenon are mahogany. Its easier gluing shims onto a tenon than into a mortise. Ditto for getting shims around the bottom of the tenon.
