Binding Glue
Pat.Hawkins
Binding Glue
Post by Pat.Hawkins » Wed Oct 19, 2016 8:23 am
Hi Folks,
a genuine question, but also wanted to unlurk myself :-)
I have some plastic bindings for a mountain dulcimer and need to get them on within two weeks.
I think I've left my run a bit late for a mail order adhesive?
Any recommendations? - Cheers
Re: Binding Glue
Post by jeffhigh » Wed Oct 19, 2016 8:35 am
Selleys plastic glue available from Coles, Have used it several times myself.
A wipe on primer you use first then the adhesive.
lauburu
Re: Binding Glue
Post by lauburu » Thu Oct 20, 2016 6:08 am
Check out your local hobby/model shop. They have a plastic glue which smells identical to Weldon and will stick plastic to wood.
Miguel
Re: Binding Glue
Post by ozziebluesman » Thu Oct 20, 2016 9:59 am
Tarzan's grip has worked fine for me for gluing plastic to wood.
Very cheap at Bunnies.
Re: Binding Glue
Post by Jim » Thu Oct 20, 2016 10:00 am
+1 on the Tarzan's grip
Steve.Toscano
Re: Binding Glue
Post by Steve.Toscano » Thu Oct 20, 2016 12:48 pm
+2 on tarzans grip
Re: Binding Glue
Post by rocket » Thu Oct 20, 2016 12:50 pm
Weldon 16 by online order delivery time,, cuppla dayz
old_picker
Re: Binding Glue
Post by old_picker » Thu Oct 20, 2016 3:16 pm
personally I like CA gel. Used Weldon a few times and didn't bond with it :lol: even bought a couple of large tubes which I bought at a plastics place out Braeside way. It still sits unopened in a drawer in the workshop/
The CA can be a little challenging at first and after you glue your fingers to the job a couple times you learn that less is more. A little dab'll dou'ya. It setups up nice and quick but not too quick [30 secs] so you dont have to pile on the masking tape.
With a bottle of zap yellow, some catalyst, spatula and some acetone I can get the binding on, set hard and cleaned up in one go.
whoever spots the product placement quote can have the Weldon
Pat.Hawkins
Re: Binding Glue
Post by Pat.Hawkins » Thu Oct 20, 2016 4:40 pm
Hi Old_Picker is it:
for Brylcream?
I'm in my late fifties and remember Brylcream was a household name around the country:-)
Cheers - Pat
(now de-lurked and grateful for the replies)
demonx
Re: Binding Glue
Post by demonx » Sun Oct 23, 2016 8:22 am
I buy my Weldon from a local Perspex place. Cheaper than buying online too. Try a couple of your local plastic suppliers.
Re: Binding Glue
Post by Kamusur » Sun Oct 23, 2016 6:42 pm
Californian Poppy for me Pat.
Pat.Hawkins
Re: Binding Glue
Post by Pat.Hawkins » Mon Oct 31, 2016 12:30 pm
Hi Steve,
yes, I recall California Poppy also. Dad's bottle was shared with the boys on special occasions :D
back to the topic.........
Rather than plastic bindings, I have some of that black/white/black purfling.
It's around 3mm x 1mm
Can anyone see a problem with me stacking two of those to make a 6mm x 1mm and using titebond?
It's a tear-drop dulcimer so the curve is quite gentle?
