Candy apple paint
Candy apple paint
Post by 56nortondomy » Sat Jan 21, 2017 7:52 pm
I've started building a strat and I'd like to use candy apple red to paint it. The process seems to be a bit more involved than I thought, I was just wondering if some one could explain how it's done, what base coats to use eg. I have googled it and have got some info, but I'd like to get some more detailed info. if I could. Thanks Wayne
demonx
Re: Candy apple paint
Post by demonx » Sat Jan 21, 2017 8:08 pm
It's really going to depend on what products you're using and if you want a trans finish or solid.
Candy Apple in some products is just a solid red.
Candy in automotive 2k terms is a transparent colour.
If I was to do what I'd call a "Candy Apple", I'd spray the guitar clear, sand, spray, sand, spray until the entire guitar is smooth. Then spray the candy colour (trans) and then spray clear coats again.
Doing it like this will give a depth in the finish that you simply won't get from one shot type finishes.
Post by simso » Sat Jan 21, 2017 8:50 pm
I'll explain how I do my pearls, Candy apple is just a pearl paint.
Prep surface as per normal with a solid colour, the base colour (primer) is important,
Lay down a 3 coats of your colour, then your pearl coats which are clear coat with flecks of pearl mixed in, then final clear coats, they are known as a three layer paint jobs.
Post by 56nortondomy » Sat Jan 21, 2017 11:27 pm
Thanks Allan and Steve for the replies. I'm still a bit confused though. I have no idea what primer to use ( brand? colour? ) I've read white primer, then gold or silver metallic paint and then the candy.
Post by simso » Sat Jan 21, 2017 11:59 pm
You can use any type of primer, but a dark primer will deepen the base candy coat, a white primer will brighten it.
In the situation your referring to, the white primer under a base of gold will make it brighter than a grey primer or black primer
The gold is really your base colour, but as it's very light it can be influenced by the primer coat.
Post by 56nortondomy » Sun Jan 22, 2017 10:06 am
Thanks Steve, it's starting to make sense to me now.
routout
Post by routout » Sun Jan 22, 2017 1:32 pm
I believe they also ran yellow under gold ,Candy I read somewhere was a Silver ground and then the tinted clear coat .The Body shop here in Bayswater carry some nice German brand paints I'v used ,they do have the candy style stuff give em a ring you never know. :)
Post by 56nortondomy » Sun Jan 22, 2017 2:58 pm
Thanks John, what's the name of the shop? There's a couple of auto paint shops within a half hours drive from here, I might try them.
routout
Post by routout » Sun Jan 22, 2017 7:48 pm
The Bodyshop paint supplies :) not to be mistaken for the soap supplies :lol: Bayswater,Dandy ,Thomastown and Seaford .I used Debeer paint mind you it was for a bike but their web site has good info ,there was some elastic in it 4 years and not a crack very thin fiberglass .I would do a lot of research as I do and then a cooling off period :lol: then what the hey and jump in.
Post by 56nortondomy » Sun Jan 22, 2017 8:28 pm
Ok thanks John.
old_picker
Post by old_picker » Mon Jan 23, 2017 7:10 pm
I use Milsomes in ferntree gully - they carry a good range of wood lacquers as well as a comprehensive array of auto finishes and finishing accessories such as sealers, sand paper, spray guns, cutting compounds etc etc. - they'll mix you up a 500 mil tin of any colour you want including metalics and pearls.
I have used body shop also but usually tend to head back to milsomes
Post by 56nortondomy » Mon Jan 23, 2017 8:27 pm
Thanks Ray, i'll check them out.
Post by 56nortondomy » Tue Mar 07, 2017 9:30 pm
I have another question, this time about the 2k lacquer I used. I haven't used it before so I was wondering if it has the same finish process as miritone. Does it get wet sanded back and polished? If so how long do I wait before I do it?
Thanks Wayne
