Quick job I had to do yesterday
http://www.mirwa.com.au/HTS_Make_a_Pickguard.html
How to make a Pickguard
- HTS Make Pickguard.JPG (148.8 KiB) Viewed 11026 times
Re: How to make a Pickguard
Very nice howto!
One minor issue, I think one of the entries might be out of order there... you show sanding the routed edge of the pickguard after having mounted it to the body. I'd have thought this would be done before, and the picture there still seems to have it on its own, so I'm guessing that's how you do it?
I think the pickguard is first fitted to the body (complete with screws) to test final fit. It's then removed, the edges dressed up and then a final fit is done.Mic_N wrote: ↑Wed Nov 29, 2017 8:39 amVery nice howto!
Martin has it right, I make the pickguard, route the edges, drill and fit to the body, then after I know it fits, I remove the pickguard and sweeten the edges with some wet and dry sandpaper, if for some reason I find something does not fit, then I get a file out and file that section away and then dress the edges by hand
makes sense... rough fit then disassemble to finish, fair enough!
Your post proves youre paying close attention to Steve's tutorials.
Welcome to the forum
Thankya sir. Amateur woodworker and amateur guitarist(/bass/banjo/whatever) and combining the two is one of those "yeah, I have to do that some time" things, maybe put together a simple parlour guitar that'll sound woeful or something to get a feel for it. Meanwhile, I can sit and ponder
Users browsing this forum: Google and 207 guests
