peter.coombe
Post by peter.coombe » Mon Jul 30, 2018 10:16 pm
Anyone used Gidgee for back and sides? I have just strung up a flat top mandolin with ringed Gidgee back and sides and it is the best sounding flat top mandolin I have made. 1hr after putting the strings on it beat what is now the second best. When I started this mandolin I said I would never use Gidgee again, the back join was a nightmare, a blade would not go near it without tearout. However, have now changed my mind. Looks stunning and the sound is exceptional. I knew it would sound different because the back and sides were so heavy, but this was a surprise. No pictures yet, too new. Pictures later.
demonx
Re: Gidgee
Post by demonx » Tue Jul 31, 2018 9:24 pm
I started this Gidgee body on my Xmas break and it’s been put aside since. I should probably get back to it!
Only drama I had with the Gidgee was it chipping when I routed the binding recess. I also had on another guitar a Gidgee fingerboard shrink on me, it’s from a reputable supplier so should’ve been completely dry. I put that guitar aside for several months to see how/if it was going to move and it seems ok.
WJ Guitars
Re: Gidgee
Post by WJ Guitars » Wed Aug 01, 2018 10:35 am
When routing for the bindings did you try using tape on the back to minimise chipping (John Hall, 'Blue Creek Guitar' method for difficult wood)? Did you have any issues bending the sides and what was the temperature applied for bending?
I am considering purchasing a Gidgee back and sides set to build a steel string guitar with a soft cutaway. It appears to be a difficult wood to work with and likely to blunt your tools easily. I expect keeping you tools sharp and using sanding methods are the way to work with Gidgee.
demonx
Re: Gidgee
Post by demonx » Wed Aug 01, 2018 11:15 am
I never use tape like that so that’d be a no.
As far as blunting your bits, that’s a firm yes. It’s an absolute bitch to resaw as well. Blade goes wherever you don’t want it to. You’ll be sawing straight one second and then it’ll just kick off on an angle. Tough heavy stufff.
Re: Gidgee
Post by Trevor Gore » Wed Aug 01, 2018 11:48 am
For guitars, yes, a couple of times. Here's one. The other one looked much the same, but I left out the sap wood. Hard to bend the figured wood without leaving flats in it and very dense at ~1300kg/m^3. The straight grained wood planes fine, but the figured wood is pretty much sanding only. It won't even scrape very well. Very hard to male a live back guitar out of gidgee.
Re: Gidgee
Post by 56nortondomy » Wed Aug 01, 2018 5:21 pm
I've used it on a uke (posting.php?mode=reply&f=1&t=8173 ) with a cutaway, I never really had any issues with it, I also have a guitar set here which i'll be using on a SS when I get a chance.
Re: Gidgee
Post by 56nortondomy » Thu Aug 02, 2018 4:26 pm
Try again. viewtopic.php?f=25&t=7327
I think it's working this time.
peter.coombe
Re: Gidgee
Post by peter.coombe » Fri Aug 03, 2018 8:30 pm
Finally some pictures of the mandolin.
Re: Gidgee
Post by Jim » Fri Aug 03, 2018 10:18 pm
King Billy Pine top Peter?
peter.coombe
Re: Gidgee
Post by peter.coombe » Sat Aug 04, 2018 8:27 am
No it is a Red Spruce top.
Re: Gidgee
Post by Mark McLean » Sat Aug 04, 2018 8:46 am
It does look great! And you are really pleased with how it sounds - so an all round winner. We will look with interest at whether you jump into doing another one, given the difficulties.
peter.coombe
Re: Gidgee
Post by peter.coombe » Sat Aug 04, 2018 9:29 am
Well it sold on Tuesday to the first person apart from me to play it, so I have started work on another one. I have enough Gidgee for 2 more.
Gazm
Re: Gidgee
Post by Gazm » Sun Aug 26, 2018 2:13 pm
Better late than never to ask, What did you use for kerfing material on this lil beauty please Peter?
Gaz
peter.coombe
Re: Gidgee
Post by peter.coombe » Sun Aug 26, 2018 4:43 pm
King Billy Pine.
Users browsing this forum: No registered users and 189 guests
