I have had a bit of a disaster on the fretting front on my second build
Richardl wrote: ↑Tue Jan 08, 2019 6:17 amGood idea on the tang-less fret wire. I guess i assumed, being professionally slotted, it would be correct for the wire provided. Lesson learned. I had really hoped to avoid pulling the wire before the thing even gets finished, but i suppose if there is no-other way...dammit. This build has been a bit fraught with problems, I suppose you either learn from them for the next one or give up...not sure which way I'll go!
You should only have to hold the iron on the frets for a couple of minutes to soften up the glue. You'll get the frets out if you just work carefully and slowly and "walk" the fret out rather than trying to simply yank it out bodily. I'd really recommend a pair of fret pullers...the jaws are specifically designed to get under the fret head. Failing that you can grind the face flush on a set of fret nippers and use those for the pull job.Richardl wrote: ↑Tue Jan 08, 2019 10:05 amHow hot do the frets have to be to soften titebond? I might try one and see what happens. If I can't get them out without major issues, what is the downside in terms of playability if all the frets are leveled and crowned to the same height, but not completely seated? I guess the frets will have a higher profile overall.
I take the view that the water from the Titebond swells the wood surrounding the slot and the glue prevents the wood returning to original state once water has dried off. I also run a bead of water into the slot prior to fretting.
Thanks all for your suggestions folks. I was a bit surprised about titebond but it's what is recommended in the book I'm following. As for support, I'd agree it might not have been adequate but for the frets closest to the body, they were well supported and still haven't seated very well. Maybe it's a combination of all of the above but in the end, none of the frets are really well seated like my first guitar which worked perfectly with no fuss. Of all the hand tool processes, having peined quite a few knives and dovetailed planes in my time, I'm fairly confident with a hammer, so I believe it's the slots depth and possibly width.
No, the reason being is that titebond will never properly adhere to the fret. It’ll only fill up the space between the tang and the fret. It kind of defeats the purpose of glue in the first place.
That sounds pretty scary to me. My personal opinion is I’d not want water anywhere near it and as you suggested titebond is water based.
If all you want to do is fill the fret slot, sure, use titebond.
I'd apply a bit of heat as it will help soften up any glue in the wood fibres and reduce tear out. The extra time taken to apply a bit of heat is minimal.Richardl wrote: ↑Tue Jan 08, 2019 7:47 pmSo, just so I have it right as a beginner, as I have used a bit of titebond, I can just carefully pull out the frets - no heat as it won't really soften and doesn't adhere to the frets anyway. Is that the consensus?
I didn't mention but this fretboard is ebony not rosewood. Does that require a slightly wider blade kerf as its a bit harder? I don't actually have the right size saw anyway, the finest kerf I have is 0.8 mm. I have ground a hacksaw blade to 0.5 mm which might do at a pinch just to fractionally alter the existing slots. What is the kerf on a fretting saw?
Yes, I suspect the additional information may also supply a possible culprit to the problem.
Thanks, yes, I suppose I should get a fret saw. By having it professionally cut by a luthier I had hoped to avoid all these issues. The hacksaw was just an idea to avoid spending yet another $100 on a tool I'll use infrequently. The only saw available seems to be the Pax one which is not so expensive in the UK (or from Stumac or even Carbatec in Australia), but by the time it gets to NZ... the price has doubled https://www.carbatec.co.nz/product/1556 ... r-fret-saw. I did a practice fret pull on some scrap. The Titebond sure makes a difference to locking the frets in place. I'll try the softening approach with a soldering iron tonight.kiwigeo wrote: ↑Tue Jan 08, 2019 8:25 pmI'd apply a bit of heat as it will help soften up any glue in the wood fibres and reduce tear out. The extra time taken to apply a bit of heat is minimal.Richardl wrote: ↑Tue Jan 08, 2019 7:47 pmSo, just so I have it right as a beginner, as I have used a bit of titebond, I can just carefully pull out the frets - no heat as it won't really soften and doesn't adhere to the frets anyway. Is that the consensus?
Most of my fret saws have a 0.023"/0.55mm kerf. This seems to be pretty much standard for normal fret wire. The modified hacksaw might work but I suggest you get your hands on a proper fret saw.
Users browsing this forum: Google, peter.coombe and 42 guests
