Lutherie and creative recycling
Post by Kim » Thu Jan 29, 2009 5:51 pm
That is a great little binding trimmer Taff. You mentioned chatter if you cut too steep, have you tried a thicker blade? I recon a spare blade for one of those Ibex planes would be just the trick, but for some reason I feel certain you have something you could use at hand and will.
I seen something similar once where a worn down wood chisel had been clamped at the correct angle, that would work well to I suppose. Anyhow here is a link to the LMI website, they list the 10mm Ibex blade for $10USD.
http://www.lmii.com/CartTwo/thirdproduc ... IBEX+Plane
Post by Allen » Thu Jan 29, 2009 6:00 pm
Thanks for the close ups Taffy. It's a brilliant solution to a very common task. I just had to thin some purling by just a hair, and this would have worked a treat.
Post by Lillian » Thu Jan 29, 2009 11:29 pm
Taffy you are wonderful and brilliant too. Thank you.
Kim, Lie Nielsen has an inlay section. I thought their thickness gauge was over priced, but the blade might be worth it.
http://www.lie-nielsen.com/catalog.php?cat=549
I'll look later to see if Hock does smaller blades.
Users browsing this forum: Google and 28 guests
