Cheap beer huh? Its obviously XXXXAllen wrote: The whole thing didn't cost more than 10 bucks, and that is including the stubbies that it took to lubricate me....I mean wash down the dust. It' gets awfully hot up here
I have been looking for a better solution and this looks like it. I like the way that you have used the drill press as a platform. Basically it can hang on the wall the other 99% of the time that you are not binding! Very clever Allan. Thanks from JohnAllen wrote:Here's mine. Most of the time it's stored under some of the other clutter. I just dug it out to show you my set up. The guitar is clamped in a cradle and the trimer is run around the perimeter. I use a Cutter with bearings. You could also mount it permanently to the wall if that's an option for you.
It's pretty well a no brainer and changed one of the most frightening parts of building for me into one I look forward to.
It's built from some unknown species of local hardwood that I found in the tip shop. I think that they were slats from a bed frame from under the matress. The pivots are just 1/4" steel rod pounded into a really snug whole. Works for hard wood, but wouldn't be acceptable in soft wood. And then some 1'2" threaded rod for the other bits. Some scrap perspex from the tip shop as well for the trimmer mount. The base plate that I use is some walnut that I knocked together. You could use almost any type of set up for this. If I had of thought of the large steel washer I probably would have done that.
This is very nice!Hesh1956 wrote:Graham my friend most builders are generally not pleased with Dremels for cutting binding channels and favor laminate trimmers.
Here is my jig. I am thrilled with it and you can actually cut perfect binding channels blind folded and it's been done too by another builder.
Is that?...... It can't beobmit wrote:This is very nice!Hesh1956 wrote:Graham my friend most builders are generally not pleased with Dremels for cutting binding channels and favor laminate trimmers.
I also like the look of your festool collection in da back ground.
Not mine Ricardo, I was just quoting obmit's post but the setup is Hesh's. My system is a little more "down & dirty"Ricardo wrote:Nick O, I noticed your dust extractor in the background (it is the same as mine) what are the stacks on top of it, it looks like its an extension of the extraction system
Ricardo
Users browsing this forum: No registered users and 164 guests
