Lightweight router recommendations?
H3ytm@n
Re: Lightweight router recommendations?
Post by H3ytm@n » Fri Jul 22, 2011 12:47 pm
J.F. Custom wrote:
H3ytm@n wrote:
J.F. Custom wrote:I use the Stewmac base too, although I use it with the Foredom style setup.
Just out of interest... Did you get the Foredom from Stewmac as well or were you able to source it locally?
Michael.
The handpiece is Foredom, custom modified (threaded) by and sourced through stewmac to fit their router base.
The motor unit is not actually Foredom, but a cheaper Taiwanese made alternative - hence, "foredom style"....
Thanks very much for that Jeremy.
Is this the one your talking about???
http://www.carbatec.com.au/archer-power ... kit_c13150
Mike
simonm
Post by simonm » Sat Jul 23, 2011 5:07 am
J.F. Custom wrote:
As a side, I do have a Foredom Air Turbine Grinder, but have not set it up for this job. It's handpiece is a little more specialized so would require adapting for the base. It also runs at 200'000 RPM :shock:, requiring special bits too.
Holy smoke Batman, that is one fast machine.
I can see how you need special bits.
