opinions please
Re: opinions please
Post by Taffy Evans » Thu Mar 22, 2012 10:26 am
The book I used at the time and showed the doweled tenon was one by Irvin Sloane "Steel-String Guitar Construction", again late 1970's.
Re: opinions please
Post by Lillian » Thu Mar 22, 2012 11:08 am
:oops: I told you I was getting old and forgetful.
Re: opinions please
Post by simso » Thu Mar 22, 2012 10:29 pm
Nick wrote:If the guitar's too cheap to have a couple of dollars worth of 'extra' wood fitted in such an important area how come the customer's going to the trouble of a repair and not using it as a pizza paddle? :wink:
If I said the brand name here on the web, you would be astounded, think of the top 3, it was one of them.
The customer paid thousands for it and it didnt even have a bridge plate, go ISO9000 quality control.....
Re: opinions please
Post by Taffy Evans » Fri Mar 23, 2012 9:44 am
Yes Steve, as a repairer I see too much of this sloppy work just because its out of sight of the purchaser, and in top brands that cost over a grand or so. My wife has always picked on me for taking care of detail in places people will never see, my reply is "one day a repairer may take this instrument apart, they'll see".
I will advise the customer to contact their supplier and point out, politely, that they have an instrument that has apparently slipped through quality control.
One well known manufacturer said, when a manufacturing fault was brought to their attention, sorry it's 3 weeks out of warranty, I had to leave that one with the owner of the guitar.
Re: opinions please
Post by jeffhigh » Fri Mar 23, 2012 10:08 am
Wel it can't be Gibson then..... they just put the bridge plate in the wrong place don't they?
Re: opinions please
Post by Taffy Evans » Fri Mar 23, 2012 4:10 pm
Here's a couple of beauties. When the bridge was completely removed [only the pins were holding it on] it revealed the double pin holes underneath, a well respected brand.
And....the shaded area on the bridge shows the extent of the bridge plate coverage, it ended at the pin holes. Another well known brand.
Re: opinions please
Post by jeffhigh » Fri Mar 23, 2012 4:29 pm
Well the one with the big rectangular hole is a Maton I presume, but what is the other?
Re: opinions please
Post by charangohabsburg » Fri Mar 23, 2012 11:46 pm
One just has to love those well-respected-brand horror picture shows... :roll:
Re: opinions please
Post by Taffy Evans » Sat Mar 24, 2012 8:52 am
Hi Jeff, top one is a Guild, bottom a Col Clarke.
Re: opinions please
Post by jeffhigh » Sat Mar 24, 2012 10:46 am
Thanks Taffy
Philstix
Re: opinions please
Post by Philstix » Fri Mar 30, 2012 2:54 pm
I built a steel string guitar 20 years ago using the David Russell Young book. The neck is glued on with just such a heel joint. I used long set epoxy on the heel and titebond to glue the fingerboard to the top. It has been strung up and played every day for twenty years. It has not moved at all. Epoxy works well because it is an end grain to side grain join which would be problematic for hide glue or aliphitic resin, just be sure to use a good quality long set epoxy. If you screw it up you can always undo it (carefully) with acetone. But if it worries you I'd just do a bolt on.
Phil Pearson
Tod Gilding
Re: opinions please
Post by Tod Gilding » Sat Mar 31, 2012 8:50 am
Hi Phil, I did screw it up, but with a bolt and insert into the heal :D along with HHG it is now back in the hands of it's owner and he is very happy :)
Matt Bach
Re: opinions please
Post by Matt Bach » Sat Mar 31, 2012 11:52 pm
