But there's still the matter of the orientation marks on the top of the pins......I think we need to have the pins out to see if the slots are indeed orientated correctly.charangohabsburg wrote:No, I think the uppermost part of these pins should be flush with the bridge surface.Just make those holes a bit bigger!
Im not going to say a thing, but WTF
Re: Im not going to say a thing, but WTF
Martin, I will pull them out when I go to wok this morning and photo them for you
Wow that's some pretty sloppy work. At first glance it doesn't look too bad, doesn't bear scrutiny tho.
I'd be interested to know who the maker was. For $12k you'd think they'd be able to afford a decent method for putting the fret slots in the right place, and maybe they could spent a few dollars on a pair of glasses, they obviously need new ones.
Thanks mate.....Ive been thinking about those bldi pins all night.simso wrote:Martin, I will pull them out when I go to wok this morning and photo them for you
- woodrat
...at least the maker can now afford to go and do a guitarmaking course....Paul B wrote:Wow that's some pretty sloppy work. At first glance it doesn't look too bad, doesn't bear scrutiny tho.
Perhaps 'persons unknown' cobbled together stuff from the Martin reject skip?
Price you can pay for buying sight unseen.
With the full Martin blessing the prices are 4k and 12k but that instrument is not a signed out Martin.
Freight it over to Adelaide and I'll sign it for youLee wrote:Perhaps 'persons unknown' cobbled together stuff from the Martin reject skip?
You'll 'pin' your name to that?
Now I'm 'fretting'.
Now I'm 'fretting'.
Its not a martin, I took the builders name of the top, they have a website showing there guitars off, Im encouraging the person to try and get money back first before I go ahead and say who the builder is. If the builder acknowledges theres a problem then all is good, if the builder is not happy to settle with the customer or cannot see any of the issues I raised as being a problem I will happily give there name out.
WE are going to fix it, the level of repair is subject to the customers financial status and what they may get back from the purchase, at the absolute worse case scenario we will refret it correctly and cut a new nut and fit a new bridge plate to correct the pins
This builder has a range of his/her guitars and this is the cream of the crop ""supposedly""
That cannot be a factory guitar though. A factory would make all the fretboards for any given scale length all the same what with templates and CNC files. And the fret slotting guy might have an off day, but on the same day as the guy putting in the frets, and the guy drilling bridge pin holes? QC guy must have been in the bog when this one slipped through. Maybe this one was done on the day after the work xmas party?
Perhaps there is some confusion between "builder" and "marketer". No bona-fide builder would market that under their own name.
Looks like fret end file was lost down the back of the toolbox so he just used his teeth.
Dan
Perhaps you could be kind enough to tell as the top, back and sides make-up of this device?
Is this in the ball park?
Construction: Mahogany Blocks/Dovetail Neck Joint
Body Size: Grand Performance 14 Fret Cutaway
Top: Solid Adirondack Spruce
Rosette: Style 28
Top Bracing Pattern: Standard ''X'' Scalloped (Golden Era Style), Forward Shifted
Top Braces: Solid Adirondack Spruce 5/16''
Back Material: Solid Highly Flamed Hawaiian Koa
Back Purfling: Style 45 - Golden Era
Side Material: Solid Highly Flamed Hawaiian Koa
Endpiece: none
Endpiece Inlay: none
Binding: Solid Madagascar Rosewood
Top Inlay Style: Style 42
Side Inlay: none
Back Inlay: Black/Maple/Black Fiber
Neck Material: Solid Genuine Mahogany
Neck Shape: Performing Artist Profile
Nut Material: Bone
Headstock: Solid/Long Diamond/Square Taper
Headplate: Solid Madagascar Rosewood
Heelcap: Solid Madagascar Rosewood
Fingerboard Material: Solid Black Ebony
Scale Length: 25.4''
Number of Frets Clear: 14
Number of Frets Total: 20
Fingerboard Width at Nut: 1-3/4''
Fingerboard Width at 12th Fret: 2-1/8''
Fingerboard Position Inlays: Tree of Life
Fingerboard Binding: Solid Madagascar Rosewood
Finish Back & Sides: Polished Gloss
Finish Top: Polished Gloss
Finish Neck: Polished Gloss
Bridge Material: Solid Black Ebony
Bridge Style: Performing Artist Belly
Bridge String Spacing: 2-3/16''
Saddle: 16'' Radius/Compensated/White Tusq
Tuning Machines: Waverly Gold w/ Ivoroid Button
Recommended Strings: Martin Studio Performance Lifespan Phosphor Bronze Light Gauge (MSP7100)
Bridge & End Pins: Fossilized Mammoth Ivory w/ Pearl Dots
Pickguard: none
Case: 600 Series Molded - Slate Gray
Rosette: Style 28
Endpiece: none
Side Inlay: none
Nut Material: Bone
Pickguard: none
No Way .
Thanks Rob - was just a guess.
I'm guessing the makers name starts with "E"
Next letter?
Be quicker to just fix the bloody thing
No to all the above,
I can and will post more photos later, I will hold off on the manufacturers name in case its as mentioned above, someone was having a bad day, Im all ready in consultation with the builder via email, so hopefully they will come to the party and do right by this customer. In my opinion doing right will be replacement of the guitar.
If they feel that the issues raised are not of concern then name and shame with the other 100plus photos of all the things wrong IMO
Quite simply there is no way "someone" was having a bad day. At least we are clear through to "manufacturer" now.
Lord of the flies.
simso wrote:No to all the above,
If it were me, I'd rather get their money back. I'd hate for them to have to go through this all over again with another guitar.
- woodrat
+1 here Lillian.....I cant imagine that guitar was Robinson Crusoe!Lillian wrote:
Users browsing this forum: No registered users and 33 guests
