You obviously have a very good marketing department then..Ormsby Guitars wrote:Obviously I must be polishing turds...kiwigeo wrote:The only time when you should go finer than 320 grit is when you're polishing a turd.
I put heroine in the lacquer. Every client comes back for more.kiwigeo wrote:You obviously have a very good marketing department then..Ormsby Guitars wrote:Obviously I must be polishing turds...kiwigeo wrote:The only time when you should go finer than 320 grit is when you're polishing a turd.
Catwoman? Heroin may be more addictive although Halle Berry did play catwoman.Ormsby Guitars wrote: I put heroine in the lacquer. Every client comes back for more.
Users browsing this forum: No registered users and 123 guests
