Measurment advice
Measurment advice
In about two - three weeks I am going to be afford the opportunity to spend some quality time with two Martin Palors that have been dated to between 1835 and 1850. The owner has no qualms about me putting my grubby hands all over them. I promise to wash my hands first, but while I'm handling them, I want to get all the information I can out of them. I'm looking for suggestions on taking measurements and copying profiles. I have a couple of LED flashlights that I can put inside and not worry about them getting hot. I'll try them out on the piece of crap guitar that set me down this road in the first place. My camera isn't the greatest, but I'm hoping that it will be sufficient for recording the bracing. I would like to copy the neck profile if possible. I've read about Frank Ford's technique, but the epoxy stays soft too long for me to use it. Plaster of Paris will be too messy. Thoughts, tools, techniques?
Hi Lillian
I have a profile copy tool from back in my days as an engineer. All it is is a bunch of flat metal strips bunched together in a rectangular frame with a locking bolt. I found something similar online at a tool supply shop, probable available at most large hardware stores.
http://www.woodcraft.com/product.aspx?P ... ilyID=4860
Wouldn't be hard to make something up with a bunch of timber strips (paddle pop sticks) in a little frame.
As for measuring braces etc inside the guitars... you could ask if you could remove the tops
Apart from that I'm not going to be of much help, I've done the mirror on the stick thing with a little torch a bunch of times and usually end up estimation most sizes.
Have a look on the Unofficial Martin Guitar Forum.
There is a library of bracing patterns where the lads have put a light source inside their instruments and taken pics of the braces from the outside.
Fascinating stuff and really gives you a true representation of what's happening with the bracing patterns.
Thanks James, I had forgotten about those. I might even have something similar squirreled away somewhere.
Bob, that's where I got the idea from. It gives a great view of the bracing pattern, but nothing for thickness. I don't think that my arm is small enough to reach through the soundhole, but I might be surprised. I figured mirrors and a stub of a ruler.
I don't think what you had in mind will work for the brace dimensions, but I think I know what just might. Turners use a caliper that has long arms on one side of the pivot and shorter ones on the other. You measure the distance from the gap of the side not being used. I'll have to see if I can talk Michael out of his for the weekend and do a dry run with them.
Thanks Josh!
Thanks Josh!
My local art supply shop has those contour gauges in stiff plastic bristles instead of the steel ones. Probably a lot more gentle on delicate finishes.
I think that the plasticine is probably one of your better options for brace profiles. Might even be able to give you a good idea of dimensions as well if your careful. The other option might be to use some of that "Friendly Plastic" that you heat, mold and let cool to take the shape that it's pressed against.
Really looking forward to seeing what you come up with.
- DarwinStrings
Allen mentioned the moldable plastic. Stew Mac sells plastic beads that can be heated in a bag in warm water, then molded to shape. It holds it's shape when cool, then can be re-melted and re-shaped over and over. It could be used for this very well. They sell it for making glue cauls.
Waddy
- DarwinStrings
Yes Jim, everything our southern brothers take for granted in purchasing just around the corner is treated with blank stares from across the counter everywhere I go in Cairns.
It's got to the point that I don't even bother with the frustration of trying to purchase locally anymore. Something as simple as screw-in inserts for your bolt on neck can't be had locally.
- DarwinStrings
Thank you for the welcome too Martin
Agreed, at least we can keep our toes exposed, it's the covered bits that can suffer most.
Yes Allen, "blank stares" or "never heard of it" or "I think we can order it from down south but it will take two weeks" then they get the order wrong and it is another two weeks.....still I love Darwin.
Oops , where am I, ok I remember, how is that pair of martins parlors going Lillian.
Saturday is the day, unless the skies open up again and dump whatever form of precipitation it chooses on us.
I know I'll be pulling the strings off of it and want to replace them. The owner isn't a player and hasn't a clue as to what's on them right now. I'm thinking silk would be an appropriate choice. What say you all?
Users browsing this forum: Google and 95 guests
