Irony
Do they know any more about what happened yet. The last I heard was that the found the black boxes and then nothing after that.
I also heard that it was a training flight with 7 on board bound for Germany. The A320 is so very automated it sounds like equipment failure is the likely cause to me but what do I know.
What a shame for the families and the causalities.
Might have been the Static ports. They're just innocent looking little holes in a small metal panel mounted on the sides of aircraft. Usually marked quite prominently nearby with "Do Not Paint". The Pitot/Static system senses air pressure. Pitot senses the air pressure caused by aircraft movement through the air, and Static senses still air pressure. This information is used primarily for... the Flight Control Computers! I've spent many a late night investigating strange faults in the Orion auto-pilot system. Sometimes it comes down to something in the Pitot/Static system. Entrapped water, bug nests, or airframe tape (used during aircraft washes to keep water out) blocking the Static ports causing all kinds of weird stuff to happen. In the RAAF there are three levels of inspection following maintenance to ensure that these ports are free and the system works properly. You can now see why.
